When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by pvinodp
at 2024-08-08 07:19:09
Point:500 Replies:6 POST_ID:828714USER_ID:11610
Linux;Perl Programming Language;Shell Scripting
I have a hash variable in perl
my %myhash = {};
# many values are written to it.
#Some values are like string1 , string2 , string3
push (@{myHash{$key} }, $value);
now in the same file I have to call a shell script
system "/pathToShellScript/xyz.sh" , $myHash{"myArray"};
How do i access each string [comma separated] within the shell script?
my %myhash = {};
Author: pvinodp replied at 2024-08-26 23:40:50
thanks all. I have been unblocked with your help
Expert: wilcoxon replied at 2024-08-09 08:16:07
If the hash is valid and the value of THREE_IP is the arrayref (indicated by your "push @" statement) of '9.9.9.9,8.8.8.8' (plus possibly other values), my original suggestion will work fine:
Expert: ozo replied at 2024-08-09 07:18:42
myHASH = {ONE_IP}->{9.9.9.9}
{TWO_IP}->{9.9.9.9}
{THREE_IP}->{9.9.9.9,8.8.8.8}
does not look like valid perl code
what do you get with
print "@{$myHash{THREE_IP}}";
or
{local $"=","; system "/pathToShellScript/xyz.sh","{@{$myHash{THREE_IP}}}";
{TWO_IP}->{9.9.9.9}
or
Author: pvinodp replied at 2024-08-09 07:08:29
okay I will explain how my hash looks like
{TWO_IP}->{9.9.9.9}
Now I have to pass the value to the shell script whose key is THREE_IP.
I executed== system /pathTOMYShell/xyz.sh , $myHash{"THREE_IP"};
in my shell script I receive it as $1.
I echo it to see what I got, I get vector X290943845...
How do i get the string {9.9.9.9,8.8.8.8} here?
{TWO_IP}->{9.9.9.9}
Expert: duncanb7 replied at 2024-08-08 07:40:26
it seems you topic is similar to this link ?
http://stackoverflow.com/questions/2911192/how-can-i-process-a-perl-array-element-in-a-shell-script
Expert: wilcoxon replied at 2024-08-08 07:37:54
I don't follow the "comma separated" paren in your question. Are you saying you want to retrieve string2 separate from string1 or string3 (which requires another change to your code) or that you want to retrieve "string1, string2, string3" as a single argument?
That will pass an array reference - no idea if/how to get that in the shell. If you do:
then you should be able to reference the strings as normal arguments in your shell script. Each shell handles arguments a little differently (and you don't say which you are using). Most common is $1 $2 $3 $4 ... but some allow things like $argv[x] or other constructs.
If you do want to get string2 by itself, then you need to change your push line to:
