When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by artsec
at 2024-08-07 18:58:20
Point:500 Replies:12 POST_ID:828712USER_ID:11484
PHP Scripting Language;;
I am reading xml strings and saving them in an Array. The array may have several data sets and I have difficulty to extract the data records from each data set of the array. Here is the array output when I do var_dump:
array(2) { [0]=> object(SimpleXMLElement)#1 (1) { ["desktop"]=> object(SimpleXMLElement)#3 (7) { ["adDomain"]=> string(3) "ap" ["datasource"]=> string(3) "PRODUCT0" ["dns"]=> string(27) "alexHost.root.net" ["hostname"]=> string(12) "alexHost" ["ip"]=> string(14) "10.10.10.20" ["os"]=> string(13) "windows 7" ["userid"]=> string(255) "alex " } } [1]=> object(SimpleXMLElement)#2 (1) { ["desktop"]=> object(SimpleXMLElement)#3 (7) { ["adDomain"]=> string(3) "ap" ["datasource"]=> string(3) "PRODUCT0" ["dns"]=> string(27) "merryHost.root.net" ["hostname"]=> string(12) "merryHost" ["ip"]=> string(14) "10.10.10.11" ["os"]=> string(13) "windows 7" ["userid"]=> string(255) "merry " } } } User 1:
I am looking to have output like this:
adDomain ap
datasource PRODUCT0
dns alexHost.root.net
hostname alexHost
ip 10.10.10.20
os windows 7
userid alex
adDomain ap
datasource PRODUCT0
dns merryHost.root.ne
hostname merryHost
ip 10.10.10.11
os windows 7
userid merry
I tried this with foreach but foreach is not able to process all data sets in the array. It just process the first one. I tried to play with the array pointer but it print either [0] or [1] and when I try to extract data from all data sets of the array it does not do it.
Your help is highly appreciated.
John
Expert: Ray Paseur replied at 2024-08-08 07:01:06
Thanks for the points.
All of the sample scripts on my site named like RAY_temp_* are untrusted, untested, volatile, subject to change or deletion at any time without notice. When I have a test that seems to work, I post the script here at EE. It's safe to copy the EE version of the script, store it on your server, and tailor it for your exact needs.
Cheers, ~Ray
Cheers, ~Ray
Author: artsec replied at 2024-08-08 06:37:19
Great!
Thanks!
Thanks!
Expert: Ray Paseur replied at 2024-08-08 06:15:04
This seems to work correctly, too. Moving parts start on line 65. Arrays and objects are very similar when it comes to using foreach().
<?php // RAY_temp_artsec.phperror_reporting(E_ALL);echo '<pre>';// SEE http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/PHP/Q_28207137.html#a39392706// SIMULATED TEST DATA FROM DIFFERENT INPUTS (SEE datasource TAG)$xml1 = <<<EOD<desktops> <desktop> <adDomain>ap</adDomain> <datasource>PRODUCT0</datasource> <dnsDomain>alexHost.root.net</dnsDomain> <hostname>alexHost</hostname> <ip>10.10.10.20</ip> <os>windows 7</os> <userid>alex</userid> </desktop></desktops>EOD;$xml2 = <<<EOD<desktops> <desktop> <adDomain>ap</adDomain> <datasource>PRODUCT1</datasource> <dnsDomain>alexHost.root.net</dnsDomain> <hostname>alexHost</hostname> <ip>10.10.10.20</ip> <os>windows 7</os> <userid>alex</userid> </desktop></desktops>EOD;$xml3 = <<<EOD<desktops> <desktop> <adDomain>ap</adDomain> <datasource>PRODUCT2</datasource> <dnsDomain>alexHost.root.net</dnsDomain> <hostname>alexHost</hostname> <ip>10.10.10.20</ip> <os>windows 7</os> <userid>alex</userid> </desktop></desktops>EOD;// USING SEPARATE OBJECTS$obj1 = SimpleXML_Load_String($xml1);$obj2 = SimpleXML_Load_String($xml2);$obj3 = SimpleXML_Load_String($xml3);// PUT THE OBJECTS INTO AN ARRAY$arr[] = $obj1;$arr[] = $obj2;$arr[] = $obj3;// ACTIVATE THIS TO SEE THE ARRAY// var_dump($arr);// USE ITERATORS TO FIND DATA (PROPERTIES) INSIDE THE OBJECTforeach ($arr as $element){ // THIS IS AN ARRAY OF DESKTOP OBJECTS foreach ($element->desktop as $desktop) { // THIS FINDS THE PROPERTIES OF EACH DESKTOP OBJECT foreach ($desktop as $key => $value) { // FIND AND DISPLAY ONE PROPERTY if ($key == 'datasource') { echo PHP_EOL . "$key => $value"; } } }} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:75:76:77:78:79:80:
Best regards, ~Ray
Author: artsec replied at 2024-08-08 06:13:35
The sample script on your site is giving error.....
Expert: Ray Paseur replied at 2024-08-08 06:08:33
Try this design: http://www.laprbass.com/RAY_temp_artsec.php
The moving parts start at line 55. My thinking here is to preserve the string data from each of the XML documents and use string concatenation to create an array of objects containing all the data. It might also work to convert the strings to objects and concatenate them, which is what i think your code is doing now. I did not test that separately yet.
<?php // RAY_temp_artsec.phperror_reporting(E_ALL);echo '<pre>';// SEE http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/PHP/Q_28207137.html#a39392706// SIMULATED TEST DATA FROM DIFFERENT INPUTS (SEE datasource TAG)$xml = <<<EOD<desktops> <desktop> <adDomain>ap</adDomain> <datasource>PRODUCT0</datasource> <dnsDomain>alexHost.root.net</dnsDomain> <hostname>alexHost</hostname> <ip>10.10.10.20</ip> <os>windows 7</os> <userid>alex</userid> </desktop></desktops><desktops> <desktop> <adDomain>ap</adDomain> <datasource>PRODUCT1</datasource> <dnsDomain>alexHost.root.net</dnsDomain> <hostname>alexHost</hostname> <ip>10.10.10.20</ip> <os>windows 7</os> <userid>alex</userid> </desktop></desktops><desktops> <desktop> <adDomain>ap</adDomain> <datasource>PRODUCT2</datasource> <dnsDomain>alexHost.root.net</dnsDomain> <hostname>alexHost</hostname> <ip>10.10.10.20</ip> <os>windows 7</os> <userid>alex</userid> </desktop></desktops>EOD;// WRAP THE XML DOCUMENT$xml = '<thing>' . $xml . '</thing>';// MAKE AN OBJECT|$obj = SimpleXML_Load_String($xml);// ACTIVATE THIS TO SEE THE OBJECT// var_dump($obj);// USE ITERATORS TO FIND DATA (PROPERTIES) INSIDE THE OBJECTforeach ($obj->desktops as $element){ // THIS IS AN ARRAY OF DESKTOP OBJECTS foreach ($element->desktop as $desktop) { // THIS FINDS THE PROPERTIES OF EACH DESKTOP OBJECT foreach ($desktop as $key => $value) { // FIND AND DISPLAY ONE PROPERTY if ($key == 'datasource') { echo PHP_EOL . "$key => $value"; } } }} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:
Author: artsec replied at 2024-08-08 05:55:03
I store the data in an array $xml[] as you can see in my code at line #37. If I do var_dump for $xml then the output is:
Expert: Ray Paseur replied at 2024-08-08 05:51:15
When you make multiple calls to the API, do you store the data in a file or do you concatenate the data strings together like this?
<desktops> <desktop> <adDomain>ap</adDomain> <datasource>PRODUCT0</datasource> <dnsDomain>alexHost.root.net</dnsDomain> <hostname>alexHost</hostname> <ip>10.10.10.20</ip> <os>windows 7</os> <userid>alex</userid> </desktop></desktops><desktops> <desktop> <adDomain>ap</adDomain> <datasource>PRODUCT0</datasource> <dnsDomain>alexHost.root.net</dnsDomain> <hostname>alexHost</hostname> <ip>10.10.10.20</ip> <os>windows 7</os> <userid>alex</userid> </desktop></desktops> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:
You can probably concatenate the responses and wrap the entire string (multiple XML documents) in a single XML declaration. Then you need one foreach() iterator for each level of data nesting.
Author: artsec replied at 2024-08-08 05:44:01
All,
I have a script which make a query based on IP to an API which is internal and it is not on the Internet. I supply the user names which could be different in quantity each time.
Here is my code:
Here is my code:
<HTML><HEAD><TITLE>Desktop Info</TITLE></HEAD><BODY><form action="desktop.php" method=post><p> Please enter P Address :<br><textarea rows="10" cols="100" name="IP-host"></textarea><br><select name="action"><option>None</option><option>Trace Route</option></select><input name="submit" type=submit value="Look Up"></FORM><?phpif(isset($_REQUEST['submit'])){$host_ip = $_REQUEST['IP-host'];$action = $_POST['action'];if (empty($host_ip)){echo "Error: You did not supply IP Address.";exit();}$textarea = explode(PHP_EOL, $host_ip);$base_url = "https://api.net/ttt/";foreach($textarea as $ids){ $url[] = "$base_url$ids";}foreach($url as $final){$file = @file_get_contents($final);$xml[] = simplexml_load_string($file); //Pars XML output.}if (empty($xml)){echo "Error: ","$host_ip", " is not exist in XYZ referential database as a Desktop.";exit();}//var_dump($xml);foreach ($xml as $key => $out){echo "User ID: " .@$out->userid[0]."<br>";echo "Host Name: " .@$out->hostname[0]."<br>";echo "IP Address: " .@$out->ip[0]."<br>";echo "AD Domain: " .@$out->adDomain[0]."<br>";echo "DNS Domain: " .@$out->dnsDomain[0]."<br>";echo "OS: " .@$out->os[0]."<br>";}if ($action == "Trace Route"){$output = shell_exec("tracert $ip2ping");echo "<pre>$output</pre>";}}?></BODY></HTML> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:
The API output is xml with following structure:
<desktops>
<desktop>
<os>windows 7</os>
</desktop>
</desktops>
Having said that, if I run my script for two IP addresses 10.10.10.20 and 10.10.10.11. My script goes to api and get data and save it into an array. The data in array looks like:
Thanks,
John
(Edit:Redacted - Modulus_Twelve)
Expert: Ray Paseur replied at 2024-08-08 05:09:15
I think you can use the above array value to help me
Two of the experts have already asked you to post the XML strings. I'll add my voice to that request. The XML is the test data that we need. When you post that test data, we will be able to write the programming that dissects the objects created from the XML. Author: artsec replied at 2024-08-08 03:00:24
I think you can use the above array value to help me. I need a way to extract data from above array or arrays with similar structure.
Thanks,
John
Thanks,
John
Expert: MunterMan replied at 2024-08-08 02:04:04
Without seeing either the original xml or the code you are using to parse it we can't really help you. However this article may contain some pointers to help you out.
http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/PHP/A_11342-Reading-XML-Namespaces-using-PHP-Without-regex.html
Expert: duncanb7 replied at 2024-08-07 20:30:41
Could you send us exact code of the array ? It reports syntax error at my side
