When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Los Angeles1
at 2024-08-07 12:30:24
Point:500 Replies:3 POST_ID:828709USER_ID:10
Linux;;Unix Operating Systems
I am using RHEL 6.4 and can not get my mount command to work properly
mount -t nfs4 10.14.10.10:/archives/Users/xxx/xxxnulti /mnt/xxx
mount.nfs4: mounting 10.14.10.10:/archives/Users/xxx/xxxnulti failed, reason given by server: No such file or directory
I know th local file /mnt/xxx exists, but can not determine why the mount is failing.
I checked on the target, and the directly does exist
Any ideas ?
Any ideas ?
Expert: omarfarid replied at 2024-08-07 13:09:02
As woolmilkporc mentioned, /mnt/xxx should be a directory not a file.
You may try to mount remote share on /mnt and see if you get same error.
Expert: woolmilkporc replied at 2024-08-07 12:48:19
/mnt/xxx should be a directory, not a file.
10.14.10.10 should be resolveable to a hostname, by means of /etc/hosts or the DNS.
The target directory must not only exist, it must be exported. Check on the NFS4 server, because showmount does not work here (unless the directory is additionally NFS3 exported)
Expert: duncanb7 replied at 2024-08-07 12:37:51
Is it your system CentOS ? if so , please take a quick look to see it will help or not
https://www.digitalocean.com/community/articles/how-to-set-up-an-nfs-mount-on-centos-6
