When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-08-07 01:18:47
Point:500 Replies:8 POST_ID:828706USER_ID:11059
WordPress;PHP Scripting Language;MySQL Server
After my Cpanel-trial version on my VPS server was expired, and today
I start my wordpress as before go to http://mysite.com/wp/ without Cpanel License
it cames error as follows
What is that meaning or What is it caused by ?
So I gave up the old version of wordpress
Now I go http://wordpress.com to download new version of wordpress and do the following steps
1-gunzip wordpress-3.6.tar.gz
2-tar -xvf wordpress-3.6.tar
3- run index.php at mysite/wordpress/
4- setup all information such as databasename username, password, localhost & wp_prefix
5- all setup setting is passed, and then go to wordpress, it generate
the same error as my old version of wordpress
Why it generated the same error for old version and re-install new version without
Cpanel even the mysql is okay ?
Be Reminded: the old directory is at mysite/wp/ and the new directory is at mysite/wordpress/
Please advise kindly
Fatal error: Cannot redeclare class Walker_Page in /home/mysite/public_html/wp/wp-includes/post-template.php on line 970
Author: duncanb7 replied at 2024-08-09 02:12:25
-Delete old wp
-Re-install wp
-create new database for wp
-and using following php code for reclare class error
if(class_exists('WP_Themes_List_Table') != true){
//code
-Re-install wp
//code
Author: duncanb7 replied at 2024-08-07 05:25:02
for sharing server, CPanel is free, for VPS server, I need to buy package license from Cpanel
with $14 USD/month for 15 licenses.
I don't have any hosting clients and I don't need Cpanel License
So I don't want to pay addition $14/month for Cpanel
Expert: Ray Paseur replied at 2024-08-07 05:12:44
Just curious... How much money are you saving by removing cPanel? I don't really need to know -- it's a rhetorical question, intended to lead you in the direction of discerning value versus price. Weigh the financial savings against the cost of inconvenience and disruption that it seems to be causing for you.
Expert: julianH replied at 2024-08-07 03:47:25
No
This has nothing to do with cron
PHP is saying it has already found a declaration of the class Walker_Page.
Then well done you have found a new one and you are unlikely to find a solution here.
However, several of the articles I read suggested that you remove certain items from the WP package before uploading - which seems to solve this problem for other people who have reported it.
I have read all google stuff and find no solution.
Author: duncanb7 replied at 2024-08-07 02:59:53
Do you think I delete all cpanel cron-job in cron file since it is expired,
and that might be helping to solve the issue ?
0 6 * * * /usr/local/cpanel/scripts/exim_tidydb > /dev/null 2>&1
30 5 * * * /usr/local/cpanel/scripts/optimize_eximstats > /dev/null 2>&1
47 21 * * * /usr/local/cpanel/scripts/upcp --cron
0 1 * * * /usr/local/cpanel/scripts/cpbackup
35 * * * * /usr/bin/test -x /usr/local/cpanel/bin/tail-check && /usr/local/cpanel/bin/tail-check
45 */4 * * * /usr/bin/test -x /usr/local/cpanel/scripts/update_mailman_cache && /usr/local/cpanel/scripts/update_mailman_cache
30 */4 * * * /usr/bin/test -x /usr/local/cpanel/scripts/update_db_cache && /usr/local/cpanel/scripts/update_db_cache
45 */8 * * * /usr/bin/test -x /usr/local/cpanel/bin/optimizefs && /usr/local/cpanel/bin/optimizefs
30 */2 * * * /usr/local/cpanel/bin/mysqluserstore >/dev/null 2>&1
15 */2 * * * /usr/local/cpanel/bin/dbindex >/dev/null 2>&1
15 */6 * * * /usr/local/cpanel/scripts/autorepair recoverymgmt >/dev/null 2>&1
*/5 * * * * /usr/local/cpanel/bin/dcpumon >/dev/null 2>&1
59 5 * * * /usr/local/cpanel/whostmgr/docroot/cgi/cpaddons_report.pl --notify
10,25,40,55 * * * * /usr/local/cpanel/whostmgr/bin/dnsqueue > /dev/null 2>&1
Expert: julianH replied at 2024-08-07 02:35:58
Have you tried this wp forum post?
http://wordpress.org/support/topic/cannot-redeclare-class-walker_page-after-attempted-update
Author: duncanb7 replied at 2024-08-07 02:08:20
I have reboot my VPS server a lot of times after Cpanel expired.
what should I check on php.ini
Expert: AdHe5 replied at 2024-08-07 02:00:11
I'm just guessing but probably the problem is that cpanel uninstall messed up your php configuration. Did you restart apache after cpanel uninstall? Did you check your php.ini file for errors?
