When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by kevp75
at 2024-08-05 08:36:21
Point:500 Replies:5 POST_ID:828700USER_ID:11595
Apache Web Server;Components;Web Servers
I have a ExpressionEngine install, that is running 2 websites (yes, my licensing is all set).
Since I have added a domain to point to the second site, I need to update the old links: http://mysite.com/othersite to redirect to http://othersite.com
So, even though http://othersite.com brings up the other site, when I attempt to add:
RewriteEngine On
RewriteBase /
Redirect 301 /othersite http://othersite.com
to mysite.com root .htaccess file, it ends up causing a redirect loop for othersite.com
How can I fix this?
RewriteEngine On
RewriteBase /
How can I fix this?
Expert: duncanb7 replied at 2024-08-08 10:08:53
Thanks, you are welcomed
Author: kevp75 replied at 2024-08-08 09:49:59
Thank you for this
Expert: duncanb7 replied at 2024-08-08 09:30:12
100 points EXCELLENT
It just redirect http://mysite.com/othersite to http://othersite.com
missing ".com" in http://othersite.com
RewriteRule ^(.*)$ http://othersite.com/$1 [R=301,L]
talk you later
talk you later
Author: kevp75 replied at 2024-08-08 09:25:14
Can you explain to me what this does? Then I will accept.
Yes, I have tested it and it does work.
Expert: duncanb7 replied at 2024-08-08 08:54:09
400 points EXCELLENT
You just want to redirect right ?
from http://mysite.com/othersite to http://othersite
put three sentence on your.htaccess and that is all
RewriteEngine On
RewriteCond %{HTTP_HOST} ^.*mysite.com/othersite$ [NC]
RewriteRule ^(.*)$ http://othersite/$1 [R=301,L]
RewriteEngine On
