When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rsand2
at 2024-08-03 21:03:59
Point:500 Replies:2 POST_ID:828693USER_ID:11587
Miscellaneous Programming;;Java Programming Language
I am trying to understand how to properly use the ResourceConfig class in Jersey 2.0. What is the proper Jersey2 pattern for configuring a web application with environment-specific parameters (e.g. backend database connection info)? The point is to configure the application when deployed on Jersey Server, and also to configure the application when launched via JerseyTest.
Can I use ResourceConfig for this purpose? If so, can someone point to an example of how to use it to configure an Application in a Jersey Server?
Some more background on my question and what I'm trying to achieve:
Here's a simple example of what I'm doing with my other servlets (e.g. unrelated to Jersey):
<servlet>
<servlet-name>MyServlet</servlet-name>
<servlet-class>com.idfconnect.MyServlet</servlet-class>
<init-param>
<param-name>myAppConfigFile</param-name>
<param-value>/etc/idfconnect/myapp.conf</param-value>
</init-param>
</servlet>
You can see, my servlet reads the param, gets the path to the conf file, and loads
the conf file, which has all of its environment-specific configuration properties.
So the reason for this post is that I want to use a similar approach with my Jersey2 application - when deployed on a Jersey server, I have some mechanism to pass in initialization parameters, and when deployed using JerseyTest, I have an alternate mechanism to pass in such parameters. My question is what is the proper technique in Jersey2 to accomplish this?
Thanks for any help!
<servlet>
<init-param>
</init-param>
</servlet>
Author: rsand2 replied at 2024-08-03 21:12:02
:) That thread is also me, asking the same question. The answer provided in that thread didn't actually answer my question and I haven't gotten any replies to my subsequent posts to that mailing list, so I figured I'd try here
Expert: duncanb7 replied at 2024-08-03 21:09:35
That link may help you
http://jersey.576304.n2.nabble.com/question-about-ResourceConfig-td7580974.html
