When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by frugalmule
at 2024-08-03 20:58:45
Point:500 Replies:16 POST_ID:828692USER_ID:11585
Microsoft Operating Systems;;
We are trying to improve the process of re-building a customer's PC with either XP, Vista, W7 or W8 depending on what it came with. Of'course, the primary difficulty of putting the original OS back onto the machine is that the drivers are often needed from the manufacturer website.
Let's assume for the purpose of this conversation that the repair or recovery partition is corrupt or otherwise unavailable.
This means we need to re-install and vendors like Dell, even with the right service tag, have multiple drivers listed for each component. The NIC or Wireless drivers are particularly troublesome, and even if all the drivers are clear, it's still a huge time waster to look for them all and ensure that they work properly.
Is there a quick solution to ensure that the machine has the correct drivers without having to track them each down individually from each vendor?
Expert: John Hurst replied at 2024-08-19 20:02:45
@frugalmule - Thanks and I was happy to help.
.... Thinkpads_User
.... Thinkpads_User
Expert: John Hurst replied at 2024-08-05 05:31:04
46 points EXCELLENT
Not sure about Lenovo
All I specify for clients are Lenovo machines. The driver matrix section is excellent for getting drivers. Thinkvantage Software Update works quite well. And Lenovo will sell you recovery DVD's at nominal cost.
.... Thinkpads_User
.... Thinkpads_User
Expert: nobus replied at 2024-08-04 23:56:27
45 points EXCELLENT
this may also help :
http://driverscollection.com/
http://driverpacks.net/driverpacks
other tools :
http://driveridentifier.com/
http://drp.su/
i must say imo no automatic program is 100% correct, but they surely doa good job
other tools :
http://drp.su/
Author: frugalmule replied at 2024-08-04 21:06:46
Thank you for all the suggestions. So far, we have the following:
Manufacturers websites - Vendors like Dell make finding the right NIC or wireless driver nearly impossible for many models. HP is a little better but nothing to write home about. Asus is pretty good but still not an easy procedure. Not sure about Lenevo.
Slimdrivers - Looks good for updating drivers once the correct ones are already there.
DriverBackup - Excellent solution as long as the system can be booted in safe mode.
DriverEasy - Appears to do both but not until drivers are already there, is a little pricey, and requires per machine activation.
Expert: Mohammed Khawaja replied at 2024-08-04 20:28:14
45 points EXCELLENT
Prior to rebuilding, install DriverBackup and backup all drivers to a USB key. This way you do not have to go to manufacturers website and download drivers.
https://www.google.ca/search?q=driverbackup&ie=utf-8&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&gws_rd=cr
Expert: John Hurst replied at 2024-08-04 04:57:02
45 points EXCELLENT
I agree with Nobus and Rindi with respect to visiting the vendors' site for drivers. I do that myself.
Another thing myself and a colleague are doing is creating Images on a USB hard drive of systems we have built with Symantec Ghost. One or two large USB drives will hold a lot of images for a small client. If you have multiple like machines, you can build a common image. This approach is a lifesaver when something goes wrong.
We have experimented with local (on the computer) backups of images. This works as well, but we have had some issues with recovery, and of course, the approach does not work if the hard drive fails. The first approach above is more robust.
It is really important to build good images first and test them well.
.... Thinkpads_User
.... Thinkpads_User
Expert: nobus replied at 2024-08-04 04:29:55
45 points EXCELLENT
duncan - slimdrivers is FAST + FREE
Expert: duncanb7 replied at 2024-08-04 01:20:11
he wants everything in automation
Expert: rindi replied at 2024-08-04 01:14:20
45 points EXCELLENT
It usually is pretty straight forward to visit the manufacturer's site and download the drivers. If they have multiple versionsof devices in the unit, for the wireless or lan adapter for example, quickly opening the cover to that part and noting the markings on the device is also a simple task. You probably have to open the box anyway to replace the HD, or to clean out the dust, as PC's like that usually need a clean out...
Apart from that, if the disk is gone and the owner ommited to create his own recovery media when he got the PC, you should order recovery media replacements from the manufacturer. That will ensure you stay properly licensed, and the drivers should be already included.
So generally reinstalling the OS and it's drivers really is the least of the problems. What takes more time is to install and configure any other software which the customer had on the PC and you know nothing about, and to restore data. Or to convince him to buy a new OS because the original isn't available anymore or won't be soon (like XP).
Expert: duncanb7 replied at 2024-08-04 00:05:14
45 points EXCELLENT
do it all automation is no problem at al todays but need pay $
otherwise you need to computer & programming expert , do it by yourselve
Expert: nobus replied at 2024-08-03 23:57:13
46 points EXCELLENT
i recommend the manufacturerrs site for downloading drivers
but since you want a more "automated" system, you can use a service like these :
www.drivereasy.com
https://www.slimwareutilities.com/slimdrivers.php
**you can also run windows updates>optional updates, andd let it install drivers - but that is not automated also
www.drivereasy.com
Expert: duncanb7 replied at 2024-08-03 21:20:03
46 points EXCELLENT
I think you need a script that can
detect all computer device driver that whethe it is
in problem or not, if yes, just fix it and updated its laterst driver.
there is certain tool on line, please check it on google if need
If you need re-install OS without any DVD disk, just go to
search any item in google, " installation Window online"
Author: frugalmule replied at 2024-08-03 21:16:30
I would rather rebuild/reinstall the OS.
Expert: duncanb7 replied at 2024-08-03 21:13:36
46 points EXCELLENT
What do you want for repair besides that ?
Author: frugalmule replied at 2024-08-03 21:11:06
Yeah but that only repairs the registry.
Expert: duncanb7 replied at 2024-08-03 21:05:40
46 points EXCELLENT
most window system(....xp, window7..etc.) already have window system automaticion recovery software installed,
so just go
computer--->properties-->advance setting-->advance-->click repair setting and
chose those setup setting to start quick repair/recovery, in which you
can recover the system to date you want or you setup the check point before(or in advance)
so just go
