When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by onepiolin
at 2024-08-03 16:23:58
Point:500 Replies:7 POST_ID:828690USER_ID:11582
Microsoft Excel Spreadsheet Software;;Microsoft Office Suite
I have toolbar item under Add-Ins that is giving me an error message. I looked in the Add-ins options and found nothing that shows anything out of the straight excel install.
Where would I look at to remove this Add-in? or fix this erro?
Expert: Rory Archibald replied at 2024-08-05 01:33:35
Based on the error message it looks like a toolbar that was created by a workbook. Try right-clicking one of the buttons and choosing 'Delete custom toolbar'.
Expert: andrewssd3 replied at 2024-08-04 13:59:12
Xite appears to be some sort of people management tool, which has obviously been on her machine at some time. As TMekeel suggested, there may be an uninstall option on the control panel, but you have checked that. You say you have loooked under Excel Options...Add-ins - have you also looked for COM add-ins? (see screenshot).
If it's not there it could possibly be a file in her XLSTART folder. Excel automatically opens any file in the <application data>MicrosoftExcel folder, so it could be there too. The application data folder location depends on your windows version, but you can normally find it by going to an Explorer window, and typing %APPDATA% in the address bar. Then find the subdirectory ...MicrosoftExcelXLSTART.
Expert: duncanb7 replied at 2024-08-03 21:00:28
go to computer folder and search XiteReport.xls in search box , if no file found, go to get the new one
if Yes, just the add-in location editing and make sure location is correct.
By the way why xls file can be add-in file ? , I though just vbs library file can be
Expert: TMekeel replied at 2024-08-03 18:31:22
It looks like this is a reporting tool from some program, but I cant seem to find any more info than that. What programs are installed on the machine that you do not recognize?
Expert: TMekeel replied at 2024-08-03 18:24:23
What if you choose logout on the toolbar?
Author: onepiolin replied at 2024-08-03 18:02:39
No. it's for another user. There's no uninstall option.
She doesn't know how it got there.
Expert: TMekeel replied at 2024-08-03 17:12:50
Did you install the toolbar?
Is it in add/remove programs? (uninstall program in control panel in Win7)?
