When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by andreas_rafn
at 2024-08-03 07:34:39
Point:500 Replies:3 POST_ID:828687USER_ID:11578
Microsoft Visual Basic.Net;Extensible Markup Language (XML);.NET
I'm currently learning the XML features of VB.NET and Visual Studio 2010, and I have learned how I can enable intellisense in a XML file by associating it with a schema, and this works well. However since I'm mostly generating xml and not reading data from an xml file, I would like to be able to do the same when writing xml in a VB.NET module, class etc.
e.g. when writing xml directly in vb.net code like this:
Dim JohnDoe As XElement = <Person Name="John Doe"> <Height>180</Height> <HeightUnit>Meter</HeightUnit> <HeightUnitType>Metric</HeightUnitType> </Person> 1:2:3:4:5:
Is this possible?
Expert: duncanb7 replied at 2024-08-03 08:44:56
Thanks and good to hear you solve the issue
Author: andreas_rafn replied at 2024-08-03 08:42:03
I did in fact read it earlier, but looking at it again I spotted that the solution to my problem was to add a targetNamespace attribute manually to my schema (it was not done by visual studio) in order for me to be able to import it and use intellisense in the vb.net code.
Expert: duncanb7 replied at 2024-08-03 07:44:34
Did you read this before ?
http://msdn.microsoft.com/en-us/library/bb531325.aspx
