When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by jcasiotis
at 2024-08-03 01:33:16
Point:500 Replies:15 POST_ID:828679USER_ID:11568
Microsoft Operating Systems;Microsoft Windows Operating Systems;Microsoft Server
is there a way to stop users installing programs without admin rights
i have notice some programs are still installing without admin rights
see attached example .. .
Expert: Netminder replied at 2024-08-13 02:15:33
Accepting to re-start the closing process.
Netminder
Senior Admin
Netminder
Senior Admin
Expert: Modulus_Twelve replied at 2024-08-05 06:22:00
jcasiotis,
You now have four Experts involved in your question. If you are still looking for a solution, please respond to them. Otherwise, please restart the delete process.
A Moderator will check back in 48 hours to see if you need further assistance.
Modulus_Twelve
Community Support Moderator
(http://www.experts-exchange.com/R_22454.html)
Modulus_Twelve
Expert: Modulus_Twelve replied at 2024-08-05 06:21:16
duncanb7 and takecoffe,
Blind links (a URL with little or no explanation) are not welcome on EE as Experts are expected to add some value in their posts.
In future, please provide an explanation as to what the Asker should look for in the link and a summary of the page's relevant content - see http://support.experts-exchange.com/customer/portal/articles/1162518-using-off-site-content-on-experts-exchange.
Modulus_Twelve
Modulus_Twelve
Expert: Modulus_Twelve replied at 2024-08-05 06:20:43
jcasiotis and McKnife,
I have removed off-topic content.
Modulus_Twelve
Modulus_Twelve
Expert: McKnife replied at 2024-08-04 06:20:52
166 points GOOD
Software installations cannot be prevented, sorry. But you can prevent them from running all but a number of defined executables which does solve your problem. And that can be done though software restriction policies.
(Edit: Off-topic content removed - Modulus_Twelve)
Expert: HostOne replied at 2024-08-04 01:06:37
167 points GOOD
Windows GPO only allows you to prevent installation of software which uses the add/remove programs style of installation. If a program simply "runs", like many torrents, Chrome etc (which just install themselves in the user hive of the registry and local c:users<username>/appdata type locations: the above referenced GPO to prevent installation takes no action.
Instead, you can blacklist various exe filenames from running or you can whitelist certain ones and only allow those to run.
For example, if the user should old be running MS Office apps and maybe 1 or 2 other apps, create a whitelist for those and *deny* running any other .exe files. This will stop the user from running those applications or installation things like uTorrent or Chrome but of course, it's reasonably difficult to maintain if the users have a dynamic list of applications they want to run.
This is what takecoffee is referring to above and it *will* prevent users from running or installation applications like Google Chrome.
However be aware that blacklisting specific applications is a losing and pointless battle - instead you should blacklist -everything- and whitelist only the applications you want to be allowed to run.
Expert: duncanb7 replied at 2024-08-03 03:09:23
jcasiotis, so it is your setup or seting GP issue on you window
and that is not the method or link issue
Expert: Haresh Nikumbh replied at 2024-08-03 02:55:08
167 points GOOD
Author: jcasiotis replied at 2024-08-03 02:06:50
it doesnt work... also there is now way to block google chrome installs
Expert: duncanb7 replied at 2024-08-03 01:53:04
Did you follow exact instrution to get it done ?
Use Group Policy Editor properly
You can if you wish restrict users from installing programs in Windows 7 , Windows Vista, Windows XP , Windows 2000 & Windows Server family. You can do so by using certain Group Policy settings to control the behavior of the Windows Installer, prevent certain programs from running or restrict via the Registry Editor.
Author: jcasiotis replied at 2024-08-03 01:48:05
windows 7 desktops.
see attachement
see attachement
Expert: duncanb7 replied at 2024-08-03 01:42:54
no error found during your try ?
What window are you using ?
If method we all agree that is okay, just focus on why you can not get success from the link
Author: jcasiotis replied at 2024-08-03 01:38:27
this option has already been tried and doesnt work
http://www.thewindowsclub.com/how-to-prevent-users-from-installing-programs-in-windows-7
Author: jcasiotis replied at 2024-08-03 01:37:31
Can this be done using group policy ?
Expert: duncanb7 replied at 2024-08-03 01:34:49
this link might be the answer
