When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by ramkanirka
at 2024-08-02 22:40:48
Point:500 Replies:3 POST_ID:828674USER_ID:11565
Wireless Networking;;Wireless Technologies
We have got a project related to Wireless with cisco 1600 series Aps and 2500 series WLC.
I am going for site-Survey in soon.
I am sure , first customer asks the following questions ?
1) How to find a LWAP Access point coverage ,How much distance 1600 series Access coverage?
2) Is coverage depends on freequency bands 2.4Ghz and 5Ghz or others ?
3) Which protocol gives more benifits 802.11 a/b/g/n?
4) what setting should confugure in WLC for clearing interferences (doars ,closed rooms,mirrors etc)
5) What is dbi means ,which value is good , is lower or higher?
Pls help with basics then i will reffer books to gain knowledge
Regards
Ram
Regards
Ram
Author: ramkanirka replied at 2024-08-21 23:18:10
Expert: craigbeck replied at 2024-08-03 02:43:03
Simply put, dBi is the measurement of gain when compared to a theoretical antenna. An antenna with 3dBi gain is weaker than an antenna with 13dBi gain (if they're the same type and orientation).
Reading a spec sheet will not detail how far an AP will propagate in a building with obstacles such as walls and doors. The specifications will only really tell you how far a data-rate will be sustainable in an open area and at a certain receive strength. This value is in dBm and is ALWAYS a negative number. When looking at dBm values, SMALLER numbers are better (ignoring the - sign), so -91dBm is WEAKER than -35dBm.
Strictly speaking 802.11n is an enhancement not a frequency, so when asking which is better it is usually correct to include the frequency in the same sentence as 802.11n. Therefore as an example, 802.11n is better when used at 5GHz (802.11a) as you have the ability to use 40MHz channels to provide twice as much bandwidth as 802.11n at 2.4GHz. However, if you're wanting to know which propagates further, this is usually 802.11n at 2.4GHz (depending on the construction of the building, etc).
There are no settings available on any WiFi system to clear interference caused by closed doors, etc. Technically an obstacle such as a door won't cause interference - it is merely a solid object which will only reduce the receive signal strength as the radio wave passes through it. However objects such as fluorescent lights will cause slight interference and should be avoided in the path between the AP and clients.
You can use CleanAir to assist the WLC in actively monitoring the RF environment in order to dynamically change channels, etc, but the 1600 APs only use CleanAir Express, so it's not as active as CleanAir when used with a 2600 or 3600 (for example).
Expert: duncanb7 replied at 2024-08-02 23:39:35
Please read this link:
http://www.cisco.com/en/US/products/hw/wireless/ps458/products_tech_note09186a008009459b.shtml
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
see attached file,prod-technical-reference09186a00.xls
Yes, of course
n is better and covered all IEEE802.11a,b,g standard now most people are using g
I don't understand what you mean, please write it more
One more theoretical construct needs to be understood. That is Decibels (isotropic) or dBi. It is the gain in radiation intensity of an antenna. As high as better
http://www.techrepublic.com/blog/data-center/80211-time-to-clear-up-some-antenna-misconceptions/
