When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by MONSTERSTYLE
at 2024-08-02 22:24:45
Point:500 Replies:4 POST_ID:828673USER_ID:11564
PHP Scripting Language;Cascading Style Sheets (CSS);JavaScript
I've had to install a different slideshow as it was heavily conflicting with Nextgen Gallery.
In doing so, I was able to insure it functions in IE, FF, Chrome and Safari, however... the text to the right of it no longer loads up...
PierreC, this one is for you!!
http://tinyurl.com/myuzrrb
The issue is in the white box to the right of "We Want to Hear From You!"
There is suppose to be text displayed to the right of the rotating photos... :-
I've spent about 2 hours trying to figure it out, editing css, adding code to css, etc...
Expert: AdHe5 replied at 2024-08-05 05:14:37
You are welcome! The css box model can be a little tricky sometimes.
Author: MONSTERSTYLE replied at 2024-08-03 09:02:08
Thank you AdHe!!! That did the trick!
Expert: AdHe5 replied at 2024-08-03 03:37:09
The div with rotator class is too big and push the text in overflow, that is set to be hidden. Setting the rotator floating to the left should solve the problem.
So the .rotator class should be:
.rotator {
position: relative;
float: left;
.rotator {
position: relative;
float: left;
Expert: duncanb7 replied at 2024-08-02 22:59:44
Before answer this thread,
I'd like to confirm what you want
There are three rectangle area
A-"We want to hear from you"
B- Slide show gallary
C- the blank rectangle is at the back of rect B
So,
Rect A has issue, supposed rect A is at inside of rect B and at right side of those photo, Right ?
Rect B is issue just by Rect A issue, otherwise no issue at all if Rect A issue is fixed,
the RECT B will be at the most left of the browser area, Right ?
Issue at rect C, what ?
Pleae help to clarify it first
So,
