When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by cashonly
at 2024-08-02 05:14:32
Point:500 Replies:5 POST_ID:828664USER_ID:11548
I have a chart in a workbook. What I would like to do, thru VBA, is take a "snapshot" of that chart and paste that snapshot in another workbook.
If I could do it by somehow getting the actual chart, without having to reference the original workbook, that would be great if it's not too complicated. If not, even grabbing an image of the chart would work. Any suggestions?
Author: cashonly replied at 2024-08-02 06:35:44
yahooooo,
I'm working with an existing chart, so I modified your code:
Sub CreateAndCopyChart() Dim ws As Worksheet Dim cht As Chart Set ws = Workbooks(2).Worksheets("PistCnvLSIdxMomLo-1-SMRY") Set cht = ws.ChartObjects(1).Chart cht.ChartArea.Copy Workbooks(3).Worksheets(2).Range("A2").PasteSpecial xlPasteValuesend sub 1:2:3:4:5:6:7:8:9:10:11:
This solution works best for my needs.
Thank you.
Expert: Rgonzo1971 replied at 2024-08-02 05:30:55
Hi
Or as a Picture
Or as a Picture
Sub Makro4() ActiveChart.ChartArea.Copy Range("A1").Activate ActiveWorkbook.ActiveSheet.Pictures.Paste.SelectEnd Sub 1:2:3:4:5:6:
Regards
Expert: aikimark replied at 2024-08-02 05:25:34
In certain cases, you might also consider using the Excel camera object
Expert: duncanb7 replied at 2024-08-02 05:22:13
Label the Excel chart for Chart 1
ActiveSheet.ChartObjects("Chart 1").Activate
ActiveSheet.ChartObjects("Chart 1").Copy
on other sheet
range("A1").Paste
on other sheet
range("A1").Paste
Expert: yahooooo replied at 2024-08-02 05:20:55
Sub CreateAndCopyChart()Dim ws As WorksheetDim cht As ChartSet ws = ThisWorkbook.Worksheets("Graphs")Set cht = ws.Shapes.AddChart.ChartWith cht .SetSourceData ws.Range("$B$21:$C$22") .ChartType = xl3DPie .ChartArea.CopyEnd Withws.Range("A2").PasteSpecial xlPasteValuescht.Parent.DeleteEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:
