When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by EFuerte
at 2024-08-01 15:17:15
Point:500 Replies:2 POST_ID:828657USER_ID:11539
PHP Scripting Language;;
Hi Experts!
Accordingly with the code below I'm using jQuery to call PHP code that fires a stored function.
Depending on the stored function return, a javascript function: remove_selected_nodes();
could or not run.
How to obtain the return value from the jQuery code ?
could or not run.
function deletaNodo(){ value2 = $('#nodename').val(); $('#divResultados').load('Teste_Elimina_Nodo_DespGer.php',{param1: id_sel.valueOf()});if ( xxx = "OK") // The result is posted in the div but how to obtain it here ?{ // Elimina o nodo remove_selected_nodes(); }} 1:2:3:4:5:6:7:8:9:10:11:12:13:
Thanks in advance.
Author: EFuerte replied at 2024-08-02 04:05:25
Exactly, thank you very much!
Expert: duncanb7 replied at 2024-08-01 23:01:40
Is it what you want ?
function deletaNodo(){ value2 = $('#nodename').val(); $('#divResultados').load('Teste_Elimina_Nodo_DespGer.php',{param1: id_sel.valueOf()});if ( $("#divResultados'').text() == "OK") // The result is posted in the div but how to obtain it here ?{ // Elimina o nodo remove_selected_nodes(); }} 1:2:3:4:5:6:7:8:9:10:11:12:13:
