When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by treesnow
at 2024-08-01 08:33:34
Point:500 Replies:6 POST_ID:828654USER_ID:11536
Miscellaneous Web Development;Web Browsers;Microsoft Applications
Help-->Troubleshoot-->Restart Firefox
Still same problem it keep freezing. Same problem with internet explorer I just turn off all the add-ons in IE, don't know what is that but internet explorer also not running right. MacAfee Antivirus run twice no virus or Trojan found. Need help
Thanks.
Thanks.
Expert: Rob Jurd replied at 2024-08-04 21:27:15
166 points EXCELLENT
You won't be able to remove IE but you can repair it. see here for step by step.
http://support.microsoft.com/kb/318378
Author: treesnow replied at 2024-08-01 13:35:18
Im using windows 7
Author: treesnow replied at 2024-08-01 13:34:49
I uninstall the firefox and going to remove the IE too. Where the folders are so that I delete any file related to both browsers
Expert: duncanb7 replied at 2024-08-01 09:05:27
167 points EXCELLENT
Complicated process to solve browser issue or attack might cost us a lot of time
You need to take good care about firewall
setting from your browser later.
If external site, please uninstall the browser and re-install it that
might solve the issue within 15 minutes and re-start your PC
I prefer to use Google chrome instead of Firefox or IE
go to search "download chrome" in google.com if need
Author: treesnow replied at 2024-08-01 09:01:39
I only use hotmail, careerbuilder etconly popular web sites. I can't use my browsers any more. I am using my phone right now
Expert: duncanb7 replied at 2024-08-01 08:39:41
The link you go to the site that is
doing javscript infinte programming looping so that you have such
warning message. You need to check the javscripte code, why it
always do the infinte looping and stop that
The link web page is from yours or external website ?
If it is yours code, just send out the code for us review, if not yours,
don't go to that website again
