When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by RobinMusgrove
at 2024-08-01 05:04:00
Point:500 Replies:6 POST_ID:828652USER_ID:11531
Web Browsers;;
Trying to install Java (any Verstion) always receive error "Could not create the Java virtual Machine"...
Author: RobinMusgrove replied at 2024-08-01 05:35:39
Right
Expert: duncanb7 replied at 2024-08-01 05:33:55
2013-08-01 at 05:04:00ID28201214
TopicWeb Browsers
Participating Experts1
Points500
Comments,
please see the top of the thread
so you mean you already complete uninstall JAVA on control panel and then try re-install that is not working,
RIght ?
TopicWeb Browsers
Points500
Comments,
RIght ?
Author: RobinMusgrove replied at 2024-08-01 05:30:59
Sorry I did not choice browser, My first post. I am installing it on a Windows 7 OS. Java was fine a week ago. I installed Java 7 and that seem to be when all the problem started. I ran a Java utility that removed everything related to Java in system file and registry but I cannot reinstall any version now.
Expert: duncanb7 replied at 2024-08-01 05:23:44
but I see you thread with tag of Web browser", why you quote thread related to "Web browser" ?
What system you install Java on, could you write more ?
Author: RobinMusgrove replied at 2024-08-01 05:15:42
This is a local install not going thought proxy.
Expert: duncanb7 replied at 2024-08-01 05:09:09
Do you disable any proxy server on browser completely ? please disable it first(if any) before install
