When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by apollo-13
at 2024-08-01 03:53:09
Point:500 Replies:12 POST_ID:828649USER_ID:11523
Networking Hardware;;
how can i control my network latency?
Expert: duncanb7 replied at 2024-08-01 08:22:17
83 points EXCELLENT
SOrry, it is a little bit slow
ping internal node IP >junk.txt
Ping wird ausgefhrt fr 192.168.1.148 mit 32 Bytes Daten:
Antwort von 192.168.1.148: Bytes=32 Zeit=1ms TTL=128
Antwort von 192.168.1.148: Bytes=32 Zeit=11ms TTL=128
Antwort von 192.168.1.148: Bytes=32 Zeit=31ms TTL=128
Antwort von 192.168.1.148: Bytes=32 Zeit=186ms TTL=128
my Lan i s much faster than your LAN
That is my LAN ping in Chinese versionPing 169.254.39.175 (¿¿ 32 ¿¿¿¿¿¿):¿¿¿ 169.254.39.175: ¿¿¿=32 ¿¿=1ms TTL=128¿¿¿ 169.254.39.175: ¿¿¿=32 time<1ms TTL=128¿¿¿ 169.254.39.175: ¿¿¿=32 time<1ms TTL=128¿¿¿ 169.254.39.175: ¿¿¿=32 time<1ms TTL=128169.254.39.175 ¿ Ping ¿¿¿¿: ¿¿: ¿¿¿ = 4,¿¿¿ = 4, ¿¿¿ = 0 (0% ¿¿),¿¿¿¿¿¿¿ (¿¿): ¿¿¿ = 0ms,¿¿¿ = 1ms,¿¿ = 0ms 1:2:3:4:5:6:7:8:9:10:11:12:
could you go to your LAN switch setup web page to see what you modified before ?
http://lifeandcode.net/2009/05/reduce-game-network-latency-in-windows-7-or-vista/
that might be useful to check your speed from those register key
could you show those your register key on your system for us review and compare mine ?
Author: apollo-13 replied at 2024-08-01 06:39:07
ping external node IP such as goole.com>>junk.txt
Ping wird ausgefhrt fr google.com [173.194.113.36] mit 32 Bytes Daten:
Antwort von 173.194.113.36: Bytes=32 Zeit=19ms TTL=56
Antwort von 173.194.113.36: Bytes=32 Zeit=22ms TTL=56
Ping-Statistik fr 173.194.113.36:
Pakete: Gesendet = 4, Empfangen = 4, Verloren = 0
(0% Verlust),
Ca. Zeitangaben in Millisek.:
Minimum = 19ms, Maximum = 22ms, Mittelwert = 21ms
(0% Verlust),
Author: apollo-13 replied at 2024-08-01 06:36:31
tracert internal node IP >>junk.txt
Routenverfolgung zu terminal3.heutschberg.local [192.168.1.148] ber maximal 30 Abschnitte:
1 1 ms <1 ms <1 ms terminal3.heutschberg.local [192.168.1.148]
Ablaufverfolgung beendet.
Author: apollo-13 replied at 2024-08-01 06:32:48
Ping-Statistik fr 192.168.100.148:
(0% Verlust),
Minimum = 1ms, Maximum = 186ms, Mittelwert = 57ms
(0% Verlust),
Author: apollo-13 replied at 2024-08-01 06:16:49
where find junk.txt ?
Expert: duncanb7 replied at 2024-08-01 06:09:24
83 points EXCELLENT
Could you do some ping and tracert command exmple, to see the output first ?
tracert external node IP such as goole.com>>junk.txt
send us the output of junk.txt
Author: apollo-13 replied at 2024-08-01 06:04:53
Servers windows 2008 and most domain users has win 7 also my laptop windows 7
Expert: duncanb7 replied at 2024-08-01 06:02:35
83 points EXCELLENT
What OS system are you using, could you provide more information ? otherwise we can not
help on it too much without detail networking setup, OS system ...etc?
Author: apollo-13 replied at 2024-08-01 05:58:09
I have 10 HP Procurve switches and want LAN (computers)latency to see. Because i find little bit slow network
Expert: duncanb7 replied at 2024-08-01 04:40:34
83 points EXCELLENT
http://wowpedia.org/Lowering_latency_(ping)_times
Those article're refering to change or control network latency on window
that might be you need to take a look those registry key change
Expert: nibo1 replied at 2024-08-01 04:15:04
84 points EXCELLENT
click on START >> RUN >> write /internet/speed/ >> than you will see a window that said INTERNET SPEED = 10 >> delete 10 and write 100 or more
Expert: Kash replied at 2024-08-01 03:58:43
84 points EXCELLENT
i take it you are talking about issues in LAN.
what kind of topology is in use. I would make sure the topology is best suited for your network. also, what kind of switches do have you in your network, i.e: gigabit switches. how are they connected.
what is the problem you are facing. is it for all of the users or a few ?
