When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by lrbrister
at 2024-07-31 08:48:41
Point:500 Replies:5 POST_ID:828645USER_ID:11516
Microsoft Visual Basic.Net;.NET;Microsoft Development
I have a datatable that I add rows to in a "missing id" process
missingPhoneTable.Rows.Add(extractedPhoneNumber)
How do I make sure that I only add that if it doesn't already exist?
Author: lrbrister replied at 2024-08-02 06:17:51
Clean...thanks
Expert: CodeCruiser replied at 2024-08-01 09:08:25
Here
missingPhoneTable.DefaultView.RowFilter = "PhoneNumber=" & extractedPhoneNumber
If missingPhoneTable.DefaultView.Count = 0 Then
End If
*PhoneNumber is the column name so replace it with whatever column name you have
** Assumed that extractedPhoneNumber is the string containing the value that want to check. Otherwise, replace accordingly.
End If
Expert: duncanb7 replied at 2024-07-31 09:16:37
Untesting code only, please take care of it and hope it 'll help you to start it
Dim a as integerDim i as integerDim fnd as integera = missingPhoneTable.Rows.counti =0fnd=0Do until i>aif missingPhoneTable .Row[i].cells[3].innerText = "extractedPhoneNumber " thenfnd=1elsefnd=0end ifi=i+1loopif fnd = 0 then missingPhoneTable.Rows[i+1].cells[3].innerText="extractedPhoneNumber"End if 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:
Author: lrbrister replied at 2024-07-31 09:00:53
duncanb7
How ?
How ?
Expert: duncanb7 replied at 2024-07-31 08:57:46
If find number of total rows first and check whether there is existing row cell
value is equal to "extractedPhoneNumber" in the total number of rows , If not, add it
