When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Beenardino
at 2024-07-29 18:50:50
Point:500 Replies:5 POST_ID:828638USER_ID:11508
Miscellaneous Networking;Networking Hardware;Wireless Networking
Hi All,
How can I configure my Cisco WAP4410 to make it so every time I open my browser I am redirected to a certain URL or home page?
Steps I tried: In the Web-based configuration I have already tried the generic redirect to URL:
and I paste youtube.com, then I clicked saved. Afterwards I exit out the browser and connected via WiFi, but nothing happen.....
Is there some Advance setting I need to know?
Please help I am a Cisco grasshopper.
Thank you
ps. whats with the points underneath?
Thank you
Expert: duncanb7 replied at 2024-09-06 02:12:59
500 points AVERAGE
you can set once for every in 500 computers at their directory at
windows/system32/driver/etc in which there is one file called
"hosts"
and then you can edit the file and add one sentence like this as follows
192.1.168.101 localhost in host file and delete all other localhost sentence besides
192.1.168.101 or use '#" to ignore that.
SO the file hosts like this after change
# 127.0.0.1 localhost
# ::1 localhost
Assume or for example, 192.1.168.101 is your computer network IP addresss
and also tell 500 users set default open browser url location at
"localhost"
So the users will view your home page when they open their FF, chrome browsers
since the users' default browser url's localhost is pointing to 192.1.168.101 home/index page
Supposed you have setup your computer as apache web server with localhost
and point to your index.php/home page
And later on your 500 users don't need to re-do the setting or setup for host since
it is one-time or once setup only to do action above
Hope I understood your question
"hosts"
# ::1 localhost
"localhost"
Author: Beenardino replied at 2024-09-04 14:45:51
Correct :)
Expert: duncanb7 replied at 2024-08-02 07:48:44
in other words, you need
when all 500 computers and router on, 500 users can
see the deafult webpage of the home page, youtube.com at the same/different time
RIght ?
RIght ?
Author: Beenardino replied at 2024-08-02 07:38:57
Well because I am trying to setup the AP for an entire floor not just my pc.
I dont want to setup the homepage on 500 pcs every time I want to change the home page.
Expert: duncanb7 replied at 2024-08-01 23:52:25
Why not just set home default website location on your browser you us daily
intead of cisco setup setting ?
Whever LAN computer you are on, when you open broswer, it will redirect to www.youtbe.com
