When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by conardb
at 2024-07-29 13:15:51
Point:500 Replies:5 POST_ID:828635USER_ID:11504
Oracle Database;;SQL Query Syntax
How can troubleshoot and fix this oracle database grouping error. I had this error spring up at the last minute in a development of a complex cognos report against an oracle database. Our support resources indicate it is an oracle grouping error and I'm starting from scratch on it. Has anyone had experience with this specifically or suggest the best approach to resolving. Thanks and sorry for initial vaguary. Error attached.
Attachment:OracleError.docx
Author: conardb replied at 2024-08-01 08:40:52
Thanks, it looks like some changes to the cardinality of queries in cognos are address the inclusion of needed columns in the query.
Expert: PortletPaul replied at 2024-07-29 16:43:06
167 points GOOD
It's a mistake in the query, something is missing from the group by clause.
Oracle Error: ORA-00979
Error Description:
Not a GROUP BY expression
Error Cause:
The GROUP BY clause does not contain all the expressions in the SELECT clause. SELECT expressions that are not included in a group function, such as AVG, COUNT, MAX, MIN, SUM, STDDEV, or VARIANCE, must be listed in the GROUP BY clause.
Action:
Include in the GROUP BY clause all SELECT expressions that are not group function arguments.
Error Description:
Error Cause:
Action:
Expert: duncanb7 replied at 2024-07-29 13:28:31
166 points GOOD
Take a look to see whether triggering some idea to solve the issue
http://businessintelligence.ittoolbox.com/groups/technical-functional/cognos8-l/udasql0107-error-2458285
Expert: awking00 replied at 2024-07-29 13:22:40
Can you post the query that created the error?
Expert: slightwv replied at 2024-07-29 13:21:03
167 points GOOD
Without the query it will be hard to help troubleshoot.
A grouping error means you are trying to perform an aggregate function (like SUM, COUNT, AVG, etc...) and one or more of the other columns isn't in the group by list.
For example:
select col1, col2, sum(col3) from table group by col1;
Since col2 isn't in the group by, it will generate this error.
For example:
