When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by whoam
at 2024-07-28 18:43:22
Point:500 Replies:5 POST_ID:828627USER_ID:11491
VB Script;;
Hello,
I borrowed a script form http://www.ingmarverheij.com/vmware-shared-folders-keep-profiles-in-use/.
Upon running it I get an "invalid root in registry key" error, last line char 4.
I tried to make it HKEY_LOCAL_MACHINE but got the same error.
What am I missing?
What am I missing?
'Define variables Dim objShell Dim strProviderOrder'Connect to subssystems Set objShell = WScript.CreateObject("WScript.Shell")'Read registry key strProviderOrder = objShell.RegRead("HKLMSYSTEMCurrentControlSetControlNetworkProviderOrderProviderOrder")'Remove VMware Shared Folder strProviderOrder = Replace(strProviderOrder, "vmhgfs,", "", 1, -1, 1) strProviderOrder = Replace(strProviderOrder, "vmhgs,", "", 1, -1, 1) strProviderOrder = Replace(strProviderOrder, "hgfs,", "", 1, -1, 1)'Write registry key objShell.RegWrite "HKLMSYSTEMCurrentControlSetControlNetworkProviderOrderProviderOrder", strProviderOrder, "REG_SZ" 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:
Expert: RobSampson replied at 2024-07-29 21:34:10
Hi, you are getting that error because you don't have permission to write to the value. You need to run the script from an elevated command prompt.
Run cmd.exe by right-clicking it, then "Run as administrator", then run
cscript C:ScriptsTest.vbs
Regards.
Rob.
Regards.
Rob.
Expert: duncanb7 replied at 2024-07-29 16:46:47
I mean what you get from the error message when you run F8 key on
the code at
What the error message is exactly ?
the code at
Author: whoam replied at 2024-07-29 16:42:45
Sedgwick,
strProviderOrder is
strProviderOrder is
Duncanb7,
I ammended the Dim statment as you have, but that created an error.
Expert: duncanb7 replied at 2024-07-29 01:20:44
Correction----->Dim strProviderOrder As String
and then you echo out strProviderOrder to see what is result first
Expert: sedgwick replied at 2024-07-28 22:53:14
what's the value of strProviderOrder before regWrite?
