When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rgb192
at 2024-07-28 13:52:38
Point:500 Replies:3 POST_ID:828625USER_ID:11487
PHP Scripting Language;;
this is the best tutorial I can find on simple html dom
http://www.experts-exchange.com/Web_Development/Web_Languages-Standards/PHP/A_10277-HTML-Manipulation-Made-Easy.html
However, all of this is just to wet your appetite. There are plenty of good and useful examples on the Simple HTML DOM web site. So if you're working with HTML manipulation of any sort (scraping, updating, etc...), make sure you try out this library. It can really simplify your life!
But many of the tutorials just call the find object
Where is a tutorial that is more advanced or are there more advanced examples of submitting forms.
Author: rgb192 replied at 2024-08-06 21:47:57
find does provide alot of data, and php dom is a built in alternative
thanks
thanks
Expert: Rob Jurd replied at 2024-07-29 22:43:36
So what is your question? What are you trying to do?
This is for PHP capturing a webpage and "scraping" it before sending it on to the browser.
You have made reference to submitting a form... are you trying to automate a process?
The find function is used to find html elements in the page. When you don't know the structure of the page your scraping, this would seem to be the most efficient and easiest way to get the content you are wanting to capture.
Expert: duncanb7 replied at 2024-07-29 04:02:40
Please take a look http://php.net/manual/en/book.dom.php
Write more about you want, in html or in php coding or tutorial
