When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-25 23:32:22
Point:500 Replies:6 POST_ID:828614USER_ID:11059
PHP Scripting Language;Apache Web Server;Linux Networking
http://www.google.com.hk/?gws_rd=cr#site=&source=hp&q=CDN&oq=CDN&gs_l=hp.3..0l9j0i2.2092.2480.0.2776.3.3.0.0.0.0.63.179.3.3.0....0.0..1c.1.20.hp.cVk4IDamACE&bav=on.2,or.&bvm=bv.49784469%2Cd.aGc%2Cpv.xjs.s.en_US.MpiVkF51mpA.O&fp=68e88f033c6be9af&biw=995&bih=534
I study the CDN network system will help
to speed up for my client to go to my website from the google link
And I'm doing a test on Cloudflare.com, CDN provider
My question is:
My Linux server with my domain(mysite.com) will daily use php curl() function to get huge data
from remote website at HOngkong to my Linuxserver at US . The daily extraction database time is around 6 hours
Do you think CDN system will help on my case and speed up the my php spcirpt with using curl() function from 6 hours to less hour
My question is:
Author: duncanb7 replied at 2024-07-26 02:53:37
Thanks for your reply
Expert: Dave Baldwin replied at 2024-07-26 01:27:24
I can't read the text but the diagrams show exactly the same thing. When you use a CDN, you load static content to all the CDN servers around the country and the world so that people who are browsing your site can get it from a closer and thus faster connection.
As for a better connection, I talked to my hosting company, Hurricane Electric, and they said you have to talk to your hosting company about the availability of a better connection. One that could be faster and more direct to Hong Kong. The services they offer starts at $200 per month for a 100Mbps connection and there are a lot of details to it that I didn't understand. If you could afford it, it is theoretically possible to get 1Gbps or 10Gbps connections.
Author: duncanb7 replied at 2024-07-26 00:38:55
it is also good article , please read it , http://blog.soft.idv.tw/?p=1110
Question:Only a faster and more direct connection will make any difference.
Please also write it detail or clearly
DUncan
DUncan
Expert: Dave Baldwin replied at 2024-07-26 00:31:21
You should really read this. https://en.wikipedia.org/wiki/Content_delivery_network
"believe that problem of long hour is due to the distance and connection time issue"
Yes, that is true, but CDN will not help it. Only a faster and more direct connection will make any difference.
Author: duncanb7 replied at 2024-07-26 00:21:07
becoz when do the php script from HK server to HK remte website, the speed is less than one hour.
but the php script from US server to HK remote website is 6 hour so
CDN is technolog and just help the client to find out optimizing network path or routing
in order to speed up connection time I think
Question: Can you run your PHP on your CDN?
my php script is at my server, CDN is a techonlogy and its company is NOT hosting company
Expert: Dave Baldwin replied at 2024-07-25 23:55:03
I don't know why it would. It's still the same amount of data moving the same distance. If it is fetched twice, it may even take longer. I thought CDN's were used for static data like plain HTML and images. Can you run your PHP on your CDN?
The only thing I know of that would speed up your data transfer is a much better connection. There are companies that can provide special high-speed fiber network connections to many locations around the world. See if you can find one of them that can give you a more direct and faster connection to Hong Kong.
