When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by kzamora
at 2024-07-25 09:29:34
Point:500 Replies:2 POST_ID:828611USER_ID:11463
Document Management;;
I created a ClearCase label and then applied it to an entire directory.
Afterward, I locked the label. It said "Locked for all users" which I understand it should be locked for me as well.
My understanding is that file versions which have locked labels cannot be deleted/removed.
However, I can still delete a file in my directory.
What am I doing wrong?
Author: kzamora replied at 2024-07-31 21:03:10
Thanks for giving it a whirl. I like your thinking.
My understanding now is that you have to use "triggers" to prevent accidental deletion. Here is the explanation:
The cleartool rmelem command is one of the most powerful commands in ClearCase because it removes a complete element from version control. This command destroys information irretrievably. Using it carelessly may compromise your organization's ability to support previous releases.
It's probably pretty clear why this is one of the first commands on which I like to put a trigger.
Trigger installation / Trigger script
Here is the trigger definition:
cleartool mktrtype -c "Trigger to avoid rmelem command" -element -all -preop rmelem -execwin "ccperl -e "exit 1"" -execunix "Perl -e "exit 1"" NO_RMELEM
Here is the link that talks about import triggers:
http://www.ibm.com/developerworks/rational/library/4311.html#t1
Expert: duncanb7 replied at 2024-07-29 04:13:46
Do you think it is related to chgrp or chown issue ?
if the locked file is not in the same group that you can delete it , I guess
