When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by t6bill
at 2024-07-23 18:10:45
Point:500 Replies:10 POST_ID:828603USER_ID:11454
General Laptop;;
This is an HP G72 laptop. The screen will show nothing at all, even under a bright flashlight. Video WILL output satisfactorily to an external VGA monitor. I replaced the LCD with a brand new one, and still have the same problem! Any ideas? I am Clueless.
Expert: web_tracker replied at 2024-07-24 20:14:48
Yes Nobus is right the cable is replaceble and can be easily damaged if the laptop had hinge problems, or if it was not removed properly. It is possible the video connector on the mother board may have been damaged, but then that type of damage would probably be visable.
Expert: nobus replied at 2024-07-24 03:52:46
>> it can be the video chip has a bad, or broken normal video output , while the external is still ok << then that is likely the cause
and yes the lcd video cable is also replaceable
use this for HP parts : http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=4150030&prodTypeId=321957&objectID=c00372736
a 2nd hand for 10-20 $ : http://www.ebay.com/bhp/hp-g72-parts
page 25 in the manual : LCD cable (not illustrated; includes webcam module cable) 612103-001
http://h10032.www1.hp.com/ctg/Manual/c02623152.pdf
Author: t6bill replied at 2024-07-24 03:37:46
Same thing happens when I try to boot from an Ubuntu Live CD.
web_tracker: is this cable replaceable?
Expert: nobus replied at 2024-07-24 00:49:32
test if the same happens when booting from a live Knoppix cd :
ftp://mirrors.kernel.org/knoppix-dvd/KNOPPIX_V7.0.5DVD-2012-12-21-EN.iso
Expert: santoshmotwani replied at 2024-07-23 22:11:39
Can you please uninstall your video driver and install the version compatible to your hardware.
Expert: web_tracker replied at 2024-07-23 21:49:52
Press the F key and the function key that displays the monitor. Did you unplug the external monitor and still have nothing displayed? Maybe you have a bad cable that connect to the new lcd screen you replaced.
Expert: duncanb7 replied at 2024-07-23 19:34:31
check virus issue, if not, reinstall the operation system that is
much faster to solve the issue
Author: t6bill replied at 2024-07-23 19:30:19
Other pertinent info: has the most up-to-date video driver already installed
Author: t6bill replied at 2024-07-23 19:29:44
Thanks for input santoshmotwani, but no success. I don't believe this system has an inverter board, or I would suspect that. Since I replaced the screen, and believe it to be LED backlit, I don't believe it is the backlight either.
Expert: santoshmotwani replied at 2024-07-23 18:18:57
