When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by afl_it
at 2024-07-23 09:15:50
Point:0 Replies:8 POST_ID:828600USER_ID:11447
Microsoft Server;Windows Networking;Dynamic Host Configuration Protocol (DHCP)
Hello,
We're having some strange problems with DHCP and some strange IP address assignments. The IP adress has itself as the hostname and has a very long unique ID. They're also showing as BOOTP/DHCP.
I've attached a picture so you can see what I'm talking about. There's an example of one there, but they happen all through out the day and without deleting the entries we'd rapidly run out of IP addresses.
You can't ping the IP's and Wireshark doesn't pick them up either.
I've trawled the web and have seen that others have had this problem but i can't find a definitive answer as to what it is or how to properly track it down.
To me it's like something is very briefly contacting the DHCP server and then dropping straight away, and then it keeps trying. But it's doing it so quickly that not even Wireshark can see it!!
Any help would be greatly appreciated.
Many thanks
Many thanks
Author: afl_it replied at 2024-08-07 02:16:29
Found the problem and removed it.
Expert: duncanb7 replied at 2024-08-02 08:54:26
Hope help you in next new thread
Author: afl_it replied at 2024-08-02 08:48:07
I'd written on my previous post what the problem was and how we resolved it -
Has anyone heard of the Microsoft Virtual WiFi Miniport Adapter! It only appears on some Windows 7 laptops, not all, and some have more than one.
It appears to be this that was causing our rogue IP address leases. After disabling the adaptor on all the laptops that had one the problem disappeared.
I've tried to find out why it's there but it looks like it's in development stages.
Very strange!
Very strange!
Expert: duncanb7 replied at 2024-08-02 08:45:05
Good to hear you and your find the solution
Do our reply let you delay to find your final solution ? if yes, sorry about that !
Do our reply made some or a little triggering to you so you could go to next steps ?
if yes and If you don't mind, please let us know how you solve the issue for sharing ?
Author: afl_it replied at 2024-07-29 03:07:54
Very strange!
Very strange!
Expert: duncanb7 replied at 2024-07-24 01:05:41
I reset the wireless router after press reset button at the back of the router for 30 second
and type the default password on the login page at login wbe page's IP
just restart it over from your manual
Author: afl_it replied at 2024-07-24 00:56:16
Thanks. It's definitely happening more in the day time when there are people here which leads me to believe it could be something dodgy running on someones PC. Unfortunately our AV hasn't picked anything up but then it might not be that.
duncanb7 - Have you seen this problems before and did resetting your router fix it?
Expert: duncanb7 replied at 2024-07-23 19:55:17
Reset your router it might solve it and select DHCP Enabled
