When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-14 01:35:13
Point:500 Replies:21 POST_ID:828589USER_ID:11059
Network Operations;Network Routers;Miscellaneous Networking
After PPPoE connection to my ISP on window 7 with auto configuartion setting, I get internet connectivity that is
okay and I can go to yahoo.com.
And I tried know my IP address and default gateway by ipconfig/all command.
I found the default gateway that is 0.0.0.0 Why ?
I would like to go default gateway 's login page or my ADSL(Model: NEC NTA 3110)
router login page on broswer to try setting those IP by manually
Anyone who have NTA 3110 manual, please send one copy for me.
COuld I have normal default gateway setting instead of 0.0.0.0 ?
Why now I still connect to internet(yahoo.com) with 0.0.0.0 default gateway ?
Author: duncanb7 replied at 2024-07-15 05:31:04
Anyway thanks for all of your reply
Close thread , please go to the new thread
Expert: craigbeck replied at 2024-07-15 03:27:15
Duncanb7,
People here are not obliged to help - they do voluntarily.
I notice that in the follow-up question to this one you accepted and graded an answer which was incorrect and not in context with the original question.
All this will do is discourage knowledgeable experts from helping in the future.
Author: duncanb7 replied at 2024-07-14 20:50:38
Dear craigbeck,
if you are busy, please don't reply my next new threads , thanks for your cooperation
I might be not good enough to digest your answer completely.
Expert: modus_operandi replied at 2024-07-14 19:02:45
Grade changed to 'A'
modus_operandi
EE Admin
modus_operandi
EE Admin
Expert: craigbeck replied at 2024-07-14 13:42:54
Thanks for clarifying the difference between an ADSL router and an ADSL modem.
Both answers were 100% correct, clear and concise. The fact that you do not understand the difference between a router and a modem does not help. Both Qlemo and I referred to the device as a router as YOU called the device a router in your opening post.
In terms of 100% answer - you asked why you got 0.0.0.0 - I told you why, clearly and correctly. Your modem/router/gateway doesn't assign one via the LAN ports as the PPPoE connection between the ISP and your PC is bridged via the modem/router/gateway.
I will follow the new thread.
Author: duncanb7 replied at 2024-07-14 08:57:37
Thanks all of your reply
Have a nice day ,
See you later Bye Bye
Have a nice day ,
Author: duncanb7 replied at 2024-07-14 08:55:28
So Close thread
Author: duncanb7 replied at 2024-07-14 08:14:08
In fact, your answer to the question is not quite clear enough to let me grade it to A
Sorry about that. And the grading is not depend on how many hours you took to answer it
and it is depended on the whether the answer is 100% correct to the question for the A grade or accuracy of the answer to the question
Be reminded question and answer model is mutual and interactive activity
Expert: Qlemo replied at 2024-07-14 06:01:08
If you do not understand, ask. And allow for the Experts to reply - two or three hours are not sufficient to grant a "C".
Author: duncanb7 replied at 2024-07-14 05:58:01
I could NOT understand fully to your answer
Expert: Qlemo replied at 2024-07-14 05:44:09
That doesn't answer my question. A "C" always needs a very good reason - posted.
FYI, I'm a Topic Advisor, and concerned about "quality of answers" and "quality of points given". In that role I can also change how the question got closed.
Qlemo
Topic Advisor
Qlemo
Topic Advisor
Author: duncanb7 replied at 2024-07-14 05:37:56
thanks for all of your reply, please reply the new thread if possible
Expert: Qlemo replied at 2024-07-14 05:20:55
A grade of "C" is totally inappropriate. It tells "the Experts did provide very little help, and did not improve their answers after requested for" - or, in short, an answer, but very poor. A "C" grade is given only very rarely.
The answers given are correct and on the point - why do you think they earn a "C"? As I've mentioned, we do not have any information for NTA, and I told you you might not have a router (though not in the plain).
Author: duncanb7 replied at 2024-07-14 04:47:27
I've requested that this question be closed as follows:
Accepted answer: 0 points for duncanb7's comment #a39324524
Assisted answer: 250 points for craigbeck's comment #a39324351
Assisted answer: 250 points for Qlemo's comment #a39324463
for the following reason:
it will continue in new thread
Author: duncanb7 replied at 2024-07-14 04:46:53
Author: duncanb7 replied at 2024-07-14 04:18:07
Author: duncanb7 replied at 2024-07-14 03:46:30
Typing msitake from router to modem
After talking to ISP adminstrator, they reply me the device of NEC NTA 3110 which
is ADSL modem and that is not router so that we could not login 192.168.1.1 on browser
since it is not router, just ADSLmodem plus 4 ports as switch
https://en.wikipedia.org/wiki/File:Adsl_connections.jpg
so the default gate is no use for my case
Author: duncanb7 replied at 2024-07-14 03:45:33
is ADSL modem and that is not modem so that we could not login 192.168.1.1 on browser
Author: duncanb7 replied at 2024-07-14 02:34:10
Since my window is chinese, so translate the ipconfig output as follows for your review
PPP adaptor pccw:
DNS Prefix:
DHCP Enable: No
AUto configuration: Yes
IPv4 : 218.101.120.240
Subnet mask:255.255.255.255
Default gateway:0.0.0.0
DNS server: 205.252.144.126
205.252.144.123
NetBIOS over TCPIP: Stop
Ethernet LAN:
DNS Prefix:
Desciption:Realtek RTL8139/810 Faimily Fst Ethernet NIC
DHCP Enabled: Yes
IPv4 : 169.254.109.44
subnet mask: 255.255.0.0
default gateway:
DNS server: fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over TCPIP: Enable
So the LAN setup is also in auto mode, do I need to set it manually for IP and
its gateway to 192.168.1.X and 192.168.1.1.1 respectively ?
PPP adaptor pccw:
DNS Prefix:
DHCP Enable: No
205.252.144.123
Ethernet LAN:
DNS Prefix:
DHCP Enabled: Yes
default gateway:
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Expert: Qlemo replied at 2024-07-14 02:22:19
As already said in the prior thread by other Experts, a PPPoE connection is point-to-point. IP addresses (if needed), Gateways aso. are negotiated, but insignificant. What you see is what the ISP provides as info. By default PPPoE will "route" (rather: stream) any traffic not specifically routed otherwise, but this depends on the PPPoE driver and mode.
If you set PPPoE up on your NTA (should you be able to do that, that is - don't know, cannot find a manual online), it will manage everything needed. You just have to set up your NTA as gateway. It is then not visible to you that the DSL connection uses PPPoE, and that is how nowadays DSL connections are managed - the router does all the work, your PC or other IP devices just throw there traffic to it.
Expert: craigbeck replied at 2024-07-14 01:54:10
You don't get a default gateway on the LAN adapter because the connection to the ISP is via PPPoE. That protocol doesn't need a gateway because it's not an IP-based protocol. The IP on your LAN adapter is purely to manage the ADSL router when it's in modem mode and bridging the PPPoE connection from the ISP.
If you look at the status on your LAN NIC it should have an IP address similar to 192.168.1.2
You should be able to web-browse to 192.168.1.1 to get to the ADSL router.
I wouldn't say you'd need to do anything though if the internet connection works when you connect the PPPoE session.
