When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-09 06:58:45
Point:500 Replies:9 POST_ID:828585USER_ID:11059
PHP Scripting Language;JavaScript;Apache Web Server
I would like to deny one IP address to visit my website to read all my directoy files
I tried to use the following .htaccess file and ftp it into my public_html root directory.
=================================.htaccess file =============
# -FrontPage-
ErrorDocument 404 /blank.html
<Limit GET POST>
order deny,allow
deny from 63.238.185.242
allow from all
</Limit>
<Limit PUT DELETE>
order deny,allow
deny from all
</Limit>
But it doesnt work any way even I reboot my VPS server.
COuld you tell how to make it success? Please advise
I am using apache Linux CentOS-64 system
# -FrontPage-
<Limit GET POST>
order deny,allow
allow from all
</Limit>
<Limit PUT DELETE>
order deny,allow
deny from all
</Limit>
Author: duncanb7 replied at 2024-07-09 22:53:40
For memo only:
what is different bettween httpd.conf and .htaccess
http://www.webmasterworld.com/forum92/513.htm
Author: duncanb7 replied at 2024-07-09 08:01:27
use .htaccess
Expert: gr8gonzo replied at 2024-07-09 07:54:35
So did you use htaccess or did you use iptables?
Author: duncanb7 replied at 2024-07-09 07:52:43
Expert: gr8gonzo replied at 2024-07-09 07:49:05
Here's a template for the iptables rules. Basically, you will need to modify the parts about the IP addresses to include your IP address and the IP addresses you want to block. Then you load it with iptables-restore < file_containing_the_final_rules.txt
Author: duncanb7 replied at 2024-07-09 07:47:04
Yes, it is simple logic, thanks
Expert: gr8gonzo replied at 2024-07-09 07:38:57
If you're trying to block someone who is trying to "attack" your site, you might want to consider using iptables to block the IP completely at the firewall level. That way you can easily block that IP (or more later) from everything, including FTP, mail, web, etc... It will be far more effective than .htaccess (and you can set up additional protection for yourself).
Expert: hielo replied at 2024-07-09 07:26:56
>>order deny,allow
You are instructing to first process the deny rule, THEN the allow rule. So when deny is processed 63.238.185.242 is disallowed, but when allow is processed you are "undoing" what you specified earlier. You need to reverse the order.
<Limit GET POST>order allow,denydeny from 63.238.185.242allow from all</Limit> 1:2:3:4:5:
Author: duncanb7 replied at 2024-07-09 07:25:52
it work if I change order deny,allow to order allow,deny, Why could you explain it ?
