When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by kflorian
at 2024-07-03 08:18:19
Point:500 Replies:2 POST_ID:828584USER_ID:11419
Adobe Flash;;Apache Web Server
I am streaming video via HDS from an Adobe Media Server 5.0. (I could use RTMP).
I have a 90-minute stream encoded at 8 different bit rates...from 300kbps to 5500kbps.
Some wireless connections will not play a steady stream without frequent pauses to buffer content. The buffering problem is not a function of the server because I am able to stream as much as 7500kbps when on a hardwired connection.
Here is what I've observed. If the f4m file specifies only a single bit rate, the buffer is set to 10.00 seconds and a 900kbps file streams fine to my problematic wireless connection.
<media href="../../hds-vod/Homepage/Homepage-0900.f4v.f4m" bitrate="900"/>
If, however, the f4m specifies any two or more bitrates, then the buffer is always set to 4 seconds and my problematic wireless connection will not sustain the delivery rate.
<media href="../../hds-vod/Homepage/Homepage-0300.f4v.f4m" bitrate="300"/>
It would be acceptable to hard-wire the buffer size to 10 or even 20 seconds but I do not know how to do that.
Any guidance appreciated.
Ken
Ken
Buffer-Question.pdf
- 125 KB
- Supporting screen shots and the full text of my question
Author: kflorian replied at 2024-08-02 06:00:26
I have seen those materials. After lots of experimenting I found that if I specify a single bitrate in the f4m then I can override the buffer time. If I specify two or more bitrates then the player automatically manages the buffer time. I have not found a way to override that buffer time and still specify two or more bitrates.
Expert: duncanb7 replied at 2024-08-02 03:00:04
