When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-04-04 06:11:40
Point:500 Replies:6 POST_ID:828580USER_ID:11059
PHP Scripting Language;Apache Web Server;Linux
I got one VPS account in my hosting company from which I am able to
enable and disable my server such as, shutdown, reboot , statup function.
At the beginning, when I tried to change my default root directory from
root to my expected directoy like /home/duncan/public_html by eding
the /etc/passwd with chainging as follows
root:x:0:0:root:/root:/bin/bash to root:x:0:0:root:/root:cd /home/dunican/public_html
and reboot the server, after then, I could not access SSH and my account again , Why ?
All reboot, reset password, shutdow, startup VPS is on the hosting comany member area only on its hosting company website only. I only acess my root account through SSH/putty
But now after passwd file editing, I could not access SSH anymore.
How can I access my SSH again, please advise
Expert: modus_operandi replied at 2024-04-05 18:33:28
Forced accept.
modus_operandi
EE Admin
modus_operandi
EE Admin
Expert: woolmilkporc replied at 2024-04-04 06:51:40
Your hosting company did exactly what I suggested to ask them to do.
See my last comment #a39047503!
So this comment #a39047503 should indeed be accepted as the solution instead of your comment #a39047484 which is in fact a question and not an answer.
Author: duncanb7 replied at 2024-04-04 06:41:53
I've requested that this question be closed as follows:
Accepted answer: 0 points for duncanb7's comment #a39047484
for the following reason:
my hosting company helped to fix it by get the back the original passwd by its SUper access into my server . Now it is back to normal
Expert: woolmilkporc replied at 2024-04-04 06:39:37
Can you do this ?
ssh otheruser@vps_server
where "otheruser" is a userid other than root? You can then try "sudo" or "su".
If anything fails you'll have to ask the hosting company to reset the /etc/passwd file to some previous version, or to change the "root" entry to contain a valid shell in the last column.
Author: duncanb7 replied at 2024-04-04 06:33:57
I could not run sudo command since I could not access SSH or putty
What should I ask my hosting company to do for me ?
Expert: woolmilkporc replied at 2024-04-04 06:17:28
The last column in /etc/passwd only accepts programs configured in /etc/shells.
Moreover, it may not contain command line parameters, i.e. it must be a contiguous path pointing to an allowed executable (shell).
Better add the "cd" command to one of your initialization files, like ~/.bash_profile, ~/.bash_login or ~/.profile.
If you can use sudo from an admin userid other than root do so to change the passwd file back, or if you know the root password you could also try to "su" (not "su -") to root to perform the change.
