When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-03-17 10:38:58
Point:500 Replies:10 POST_ID:828573USER_ID:11059
JavaScript;PHP Scripting Language;Linux
I am using VPS hosting with centOS 6.5 OS , and the default of time zone is MZK(MOSCOW)
So I would like to change it to America/New_York,
So I try to use command of export
export TZ=America/New_York, and try date command, it showed the America/New_York time
But when logout the shell and re-login and type date command,it shows MZK time zone again
Why, If use tzselect and setup command, it is same as export command
Where the time zone variable stored in Linux, so that I chang it permenently
Expert: modus_operandi replied at 2024-03-23 15:04:46
duncanb7,
I changed the grade to a 'B'. In cases where the Experts helped you get to a solution, but you still had to do a lot of the legwork yourself, a 'B' is entirely appropriate.
As for a 'C'... Really, the only time you should give a 'C' is when the Expert's answers are vague or incomplete, you asked for (reasonable) follow-up or clarification, and the Experts ignored you. You never really asked for any follow-up before you closed the question, and that is why the 'C' came as such a big surprise.
modus_operandi
EE Admin
modus_operandi
EE Admin
Author: duncanb7 replied at 2024-03-20 06:18:04
Ray, what you mean, why it is last contribution .
You don't agree the C grade, you want A grade.
Since your suggestion that is not matched to my solution I found at the link above.
Or I may misundertand your point ?
COuld you write it clearly what is complaint for the grade ?
Ray, I thanks you , your support and help so far within 3-year I am in EE., that I am appreciated your help.
Please don't stop to help me .
Expert: Ray Paseur replied at 2024-03-19 11:50:53
It appears that you don't get it at all about the EE culture and grading system and are not willing to learn about it. This will be my last contribution on your questions. Good luck with the others, ~Ray
Author: duncanb7 replied at 2024-03-19 10:48:05
I considered it before grading it, any issue, please advise
Author: duncanb7 replied at 2024-03-19 10:46:35
http://chrisjean.com/2009/03/03/change-timezone-in-centos/
the link is solved my issue.
Even thought, they did not provide completed solution but already help
since Ray and Modulus also trigger me to find out more in google.
So I graded it to C since the solution from them is partial only
Expert: Modulus_Twelve replied at 2024-03-19 09:48:30
Hi duncanb7,
Ray_Paseur has asked for an explanation of the grade you awarded for this question.
Please review EE's help topic on grading at http://www.experts-exchange.com/help/viewHelpPage.jsp?helpPageID=26, then post your own explanation for the grade awarded. You can post your explanation as a normal comment directly beneath this request.
As indicated in the help topic, an "A" grade should be awarded unless you have a good reason otherwise. For example, a "B" grade is acceptable if the Expert did not respond to a request for additional information or clarification. If you do receive an answer, but it seems vague, incomplete or you cannot understand it, then ask the Experts for additional clarification *before* closing your question.
A "C" grade may be the acceptable grade in the following situations...
- You have given the Experts ample time to respond to your clarification posts, remembering that they are all volunteers (and may be in different time zones to yourself).
- There are no pending Expert suggestions or requests for information.
- If, after you have done this, the answers provided by the Experts lack finality and clarity, or do not address the issue, a "C" grade is an option.
You are not under any obligation to accept an Expert comment if it did not help you find a solution. Please do not feel you are required to select a comment and then award a lower grade if you found the solution yourself, or if no solution was provided. In these cases, you can either accept your own comment as a solution or opt to delete the question.
Please also remember that an answer of "You can't do that" is sometimes the only answer to a question. If that is in fact the answer, it should be accepted as the solution, with a grade awarded as per the above guidelines.
Please respond to this request within the next 4 days with an explanation of the grade you awarded here. After this time, a Moderator will re-review this question, and may change the grade as they see fit. If you wish for the grade to be changed or have any queries about grades, please also indicate that here, and a Moderator will help you.
Thank you,
Modulus_Twelve
Community Support Moderator
(http://www.experts-exchange.com/R_17929.html)
Thank you,
Modulus_Twelve
Expert: Ray Paseur replied at 2024-03-19 07:24:38
I will ask a moderator to reopen the question so you can explain the bad grade.
Expert: smadeira replied at 2024-03-17 13:01:38
And, you will need to logout and back in to have it take effect...
Expert: smadeira replied at 2024-03-17 13:01:16
250 points GOOD
I assume you are asking about a linux timezone and not a PHP timezone based on what values you are setting.
To make it permanent you need to set the TZ value in your $HOME/.profile or your $HOME/.BASH_PROFILE as appropriate. Add this to your profile:
Expert: Ray Paseur replied at 2024-03-17 11:44:46
250 points GOOD
You can use the PHP.INI setting for date.timezone
http://www.php.net/manual/en/datetime.configuration.php#ini.date.timezone
http://www.php.net/manual/en/timezones.php
