When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-06-17 08:13:41
Point:500 Replies:8 POST_ID:828559USER_ID:11059
Apache Web Server;PHP Scripting Language;JavaScript
I would like to get the html DOM data from the follwing simple HTML page which
just output "after " to div tag at id="txt" after the body onload from javascript
function init() done
I use curl php with $dom.getElementById("txt")->nodeValue to extract
"after" but it just echo out"before" (at div tag) which is the value before excuting
javascript init() on body onload, Why ?
On FireFox firebug, we can see the complete javascript code is done and output
the "after" data when view the page source.
COuld we use php curl to extract the DOM data after parsing all javascript coding
and function execution is completed on the html web page.
I try $dom->validateOnParse = true; but it is still not working.
If we can see the "after" data on my IE broswer, we should be able to extract it
from curl php like browser's view source option , Right ?
<?php
include "include'/curl.php";
$url="http://www.mysite.com/simple.html";
$file_url=my_curl($url,"" , 7, TRUE,2,"");
if ($file_url) {
$dom = new DOMDocument();
$dom->loadHTML($file_url);
echo $dom->getElementById("txt")->nodeValue;
/------------target simple.html page
<?php
if ($file_url) {
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN" "http://www.w3.org/TR/REC-html40/loose.dtd"><html><head><script language="javascript" type="text/javascript" src="js/elib2.js"></script><script type="text/javascript">function init(){var i=1;b=7;document.getElementById("txt").innerHTML="after";}</script></head><body onload="init();"><div style="height:100px" id="txt">before</div></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:
Author: duncanb7 replied at 2024-06-17 12:08:12
Yes, after my study, you are right , php could not parse the javascript code.
The only way to solve the issue that might be
1-parse all remote site javascript , js file if any and echo all html code with javascript code ans save it in other new server html page with new iframe tag included. In the new html page, make some javascript code to save any information I want such as page's body width or height
2- ajax back the php file with query string which is consisted the information I want to send back such as the body width
Two steps run it on browers.
that might solve the issue on the cross-domain
Expert: hielo replied at 2024-06-17 10:22:25
javascript init() on body onload, Why?
Because, unlike most browsers, curl does not execute javascript code - it doesn't have a built-in javascript parser. It simply retrieves the original source code. That's why you are seeing "before". Most browsers fetch the "original" html source code. Once they receive it, then IF the browser supports javascript AND the user has javascript enabled on his/her browser, then the browser will invoke its javascript interpreter so that it executes the javascript code.
The question is : could I extract the data in php by curl and DOM from
the remote site page with all javascript function is done like the simple
init() function on body noload ?
The correct answer is No.
because the DOM parser does not interpret javascript either.
No. The "view source" feature is meant to reveal the original code (as saved on the server). The DOM that you see via Firebug is the "live" representation of the DOM at that moment in time. Since most browser's support javascript, you see "after" because the original DOM (in your example) has been altered via javascript from "before" to "after". But like I said, that does not happen if javascript is disabled/unsupported.
Author: duncanb7 replied at 2024-06-17 09:36:10
Be reminded the web page and php code is in different domain (cross-domain)
Author: duncanb7 replied at 2024-06-17 09:31:50
sorry it is no use the elib2.js, I forgot to delete it
THe question is : could I extract the data in php by curl and DOM from
Expert: Ray Paseur replied at 2024-06-17 09:25:24
What would I expect to find in "js/elib2.js" ?
Author: duncanb7 replied at 2024-06-17 08:43:10
sorry the code is no use
Just want to get the idea to solve the problem.
Is it we need to use proxy php script parsing all javascript file ?
Author: duncanb7 replied at 2024-06-17 08:40:19
You can try my example and save it into your site. since my site
is blocked by my company to outside
function init()
var i=1;b=7;
</script></head>
</body></html>
function init()
var i=1;b=7;
</script></head>
</body></html>
Expert: Ray Paseur replied at 2024-06-17 08:37:11
What is the URL of the site?
