When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-11-26 10:50:55
Point:500 Replies:2 POST_ID:828539USER_ID:11059
JavaScript;;
THe following javascript is setting different URL webiste to be fired on iframe for every 5 seconds.
my question, the following javascript is not problem at ll, but when the new url is ready to fire
my loudspeaker will be beep , and next new url link is changed, next beep is sound
on my loadspeaker. So finally I turn-off my loudspeaker. It is only happen on IE7
browser, and it is no such beep when you go different website on Firefox, chrome, opera, saferia.
Any method in javajscript can turn-off the loudspeaker when the url of iframe is change ?
Any normally, in address bar of IE7 browser,when you change the http:// address, the loudspeak
is also beep beep sound. How to avoid this on normal website seach on IE and the following javascript
program on IE7, please advise
I think no one can tolerate the beep sound when the url website address is changing on IE7 besides
you turn-off the loudspeaker but a lot of people always turn on the loudspeaker for news or entertainment
as default everyday and doesn't like such beep sound .
I don't know why IE will give us such beep sound when url address change, that might be let the
users know the new webpage is comming. I think display changing is good enough to let
users to know the page is changing.
<html><head><script type="text/javascript">playstack();function play(link){//alert(link); document.getElementById("topiframe").src=link;}function playstack() {var i=1;var s=1;var c=1;while (i < 6){var string=new Array();string[1]='http://www.yahoo.com';string[2]='http://www.facebook.com';string[3]='http://www.google.com';string[4]='http://www.facebook.com';string[5]='http://www.appledaily.com';//alert(string[i]);//window.setTimeout(function() {play(string[i]);} , 5*1000*c);(function(i){window.setTimeout(function() {play(string[i]);} , 5*1000*c);})(i);c=c+1;i=i+1;//if (s=6) {s=1;}}}</script></head><body><div class="i6" > <IFRAME name='topiframe' noresize id='topiframe' width=500 height=500 SCROLLING=no border=0 frameborder=0 src='http://www.google.com' ></IFRAME> </div> </body> </html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:
Author: duncanb7 replied at 2024-11-27 17:57:34
http://www.friedbeef.com/how-to-stop-internet-explorers-annoying-clicking-sound/
this one is easier to follow
THanks for your reply
Expert: Boa-Teng replied at 2024-11-26 12:03:09
maybe this aritcle may help you:
http://www.hotscripts.com/forums/javascript/33223-suppress-sound-ie-when-new-page-loads.html
