When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-11-18 07:36:14
Point:500 Replies:3 POST_ID:828533USER_ID:11059
JavaScript;;Hypertext Markup Language (HTML)
I would like to detect a click on body and report out what the click href link is clicking.
And I write the following example code with using function of onclick="processclick();" on body tag.
But when I click yahoo link or wiki link, the alert() is always report to the exisitng domain name
and path such as http://www.mywebsite.com/onclick.html
So whereever I click on the body area, it always report the same window.location.href whcih
is equal to http://www.mywebsite.com/onclick.html . I expect, it alert() me the yahoo or wiki path name
according to individual click
if possible, I can prevent my vistors going into
yahoo or wiki link by redirect into other link when they click the either link , this
is for example only.
How can I detect the yahoo or wiki click and its exact link path name by alert() before it load
or jump into www.yahoo.com or www.wiki.com web pages
I tried put onload="processclick();" in body tag, the result is keeping reporting the same
my website path such as http://www.mywebsite.com/onclick.html
How to capture the click event and its exact link path name
///http://www.mywebsite.com/onclick.html<html><head><script type="text/javascript">function processclick(){alert(window.location.href);}</script></head><body onclick="processclick();"><a href="http://www.yahoo.com">Yahoo Website</a><a href="http://www.wiki.com">Wiki Website</a></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:
Author: duncanb7 replied at 2024-11-18 08:13:34
html>
<head>
alert(event.srcElement.href);
event.srcElement.href="http://www.otherwebsite.com";
</script>
</head>
<a href="http://www.yahoo.com" >Yahoo Website</a>
<a href="http://www.wiki.com" >Wiki Website</a>
</body>
</html>
<head>
</script>
</head>
</body>
</html>
Author: duncanb7 replied at 2024-11-18 08:12:10
html>
<head>
</script>
</head>
</body>
</html>
<head>
</script>
</head>
</body>
</html>
Expert: nap0leon replied at 2024-11-18 07:51:07
If you don't mind moving the onlick into each <a> you can do this:
<html><head><script type="text/javascript">function processclick(obj){alert(obj.href);}</script></head><body><a href="http://www.yahoo.com" onclick="processclick(this);">Yahoo Website</a><a href="http://www.wiki.com" onclick="processclick(this);">Wiki Website</a></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:
