When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-10-23 02:44:00
Point:500 Replies:13 POST_ID:828530USER_ID:11059
JavaScript;;Hypertext Markup Language (HTML)
I have two frame to navigate to different example website and I try to use
javascript code to set attribute control on the second frame scrolling to NO but
it fail no matter what the code I use.
I try to enable the following code by clicking hef="javascript:scrolltest() function"
Method-1 parent.mainFrame.setAttribute("scrolling", "no");
Method-2 parent.mainFrame.scrolling="NO";
Method-3 mainFrame.scrolling="NO";
Method-4 parent.document.getElementById("second").scrolling = "no";
All my try is no any response in IE7 broswer
Example.html file==============================================<DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Frameset//EN" "http://www.w3. org/TR/xhtml1/DTD/xhtml1-frameset.dtd"><html><head><title>Mainpage Javascript </title><style type="text/css"></style><script language="javascript"> /* document.getElementById("myFrame").noResize = true;*/</script></head><frameset rows="200,*" cols="*" border="0"><frame name="topFrame" id="first" noresize frameborder="0" scrolling="NO" src="http://www.wiki.com" /><frame name="mainFrame" id="second" noresize frameborder="0" src="test.html?Load" scrolling="yes" /></frameset>test.html file===========================================</html><html><body><head><script type="text/javascript" >function scrolltest(){//parent.mainFrame.setAttribute("scrolling", "no");//parent.mainFrame.location.href="http://www.w3school.com";parent.mainFrame.scrolling="NO";}</script ></head><p> Testing frame</p><a href="javascript:scrolltest();">Testing scrolling in frame click<a><div><IFRAME name="myIframe" id="third" SCROLLING=yes border=0 frameborder=0 width=100% height=100% src="http://www.yahoo.com"></IFRAME></div></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:
Attachment:test.htmlexample.html
Author: duncanb7 replied at 2024-10-31 21:15:58
THanks for all of your reply
anyyway it solve some issue about scrolling bar
in this thread by iframe instead frame and
new question I may switch to new thread for scrollHeight
THanks
THanks
Author: duncanb7 replied at 2024-10-31 14:42:13
I mean if the first one iframe src content is width*height=1024*800 and
scrollwidth and scrollHieght will be around 1024*800
and if you change iframe src for the page widht and content =800*400 and
the scrollwdith and scrollHeight is still to be the bigger one as 1024*800
and the display to the last one iframe scr will leave a lot blank or empty
space at your left or bottom in the broswer.
Please advise if you understand my question
Author: duncanb7 replied at 2024-10-31 14:37:54
I mean if your first or next iframe html page 's scrollHieght and scroll width's
highest or widest content, the scrollHeight and scrollWidht value is fixed and no change
at all to the highest one even you change the the ifrmae scr to other page at the
same domain Why ?
I know scrollheight is read-only and could not be written , Is it Yes ?
same domain Why ?
Author: duncanb7 replied at 2024-10-31 14:32:31
Recent days, I have tried a lot of Iframe example , and I found iframe may
be better than frame.
But one question, in iframe,
When I try to adjust iframe width and height according to each source html page's
height and widht scrollHieght and scrollwidth. But the result the body content's
width and height is always the same as the most height or the most widest 's html
page. What I try all iframe content page or parent page is at the same domain at my
website(not cross-domain). it seems we can not able to reset the scrollHeight or scrollWidth with different html iframe content. Please review my following code
and checking the thread at http://www.experts-exchange.com/Programming/Languages/Scripting/JavaScript/Q_26513807.html
In the following code, for first time, you adust the iframe content it work by
typing "adjust button" and if you change the iframe src for short height content
by src button in input button , you will see the iframe cotent is well fit into the broswer
and leave a lot empty space at the bottom of the ifame because the first one is
long content height page.
How to solve this issue in Iframe, I try to
document.getElementById('d1').innerHTML="";
document.getElementById('d1').innerHTML="<IFRAME id='ifr' style='border:0;
margin:0; padding:0 ' name='ifr' noresize SCROLLING=noborder=0
frameborder=0 width=100% height=100% src="+link+" ></IFRAME>";
to replace document.getElementById('ifr').src=link;
It is same the scrollHeight is always as the first hit page of iframe's scrollHeight and width
Why ? Please advise
Why ? Please advise
<html ><head><title></title><script type="text/javascript">document.domain="http://www.e-hftrade.com"; function loadpage(){ var ifra=document.getElementById('ifr').contentWindow;document.getElementById('ifr').height =ifra.document.body.scrollHeight + 5;document.getElementById('ifr').width =ifra.document.body.scrollWidth + 5;} function loadpagesrc(link){document.getElementById('ifr').src=link;//document.getElementById('d1').innerHTML="";//document.getElementById('d1').innerHTML="<IFRAME id='ifr' style='border:0;//margin:0; padding:0 ' name='ifr' noresize SCROLLING=noborder=0//frameborder=0 width=100% height=100% src="+link+" ></IFRAME>";loadpage();}</script></head><body><div id="d1"><IFRAME id="ifr" style="border:0; margin:0; padding:0 " name='ifr' noresize SCROLLING=no border=0 frameborder=0 width=100% height="100%" src='longcontent.html' ></IFRAME></div><input type="button" onclick="javascript:loadpage();" value="Ajust" /><input type="button" onclick="javascript:loadpagesrc('shortcontent.html');" value="src" /></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:
Expert: Rob Jurd replied at 2024-10-30 17:48:00
125 points GOOD
Expert: Rob Jurd replied at 2024-10-30 17:47:10
You should still be able to achieve part of what you want to do using iframes and div tags. To use traditional frames means you need to update 2 parts to your site, the noframes version and the frames version.
Expert: Rob Jurd replied at 2024-10-27 19:42:37
125 points GOOD
frames are now deprecated meaning they will no longer be supported in future browsers... you still want to use them?
Author: duncanb7 replied at 2024-10-23 23:42:22
I am doing frame tutorial.
Expert: Rob Jurd replied at 2024-10-23 23:33:06
Why are you using frames?
Author: duncanb7 replied at 2024-10-23 22:23:36
frame and iframe is not a matter
And I just want to control frame scrolling in second html script, for exmple,
control frame in example.html by the javascript code in test.html
I have tried the following scrolltest() and monitor by alert() , the attribue scrolling is
changing from yes to no. But the browser is no response , it is still enable
scrolling on second frame.
alert(parent.document.getElementById('mainFrame').scrolling);
parent.document.getElementById('mainFrame').scrolling="NO"
alert(parent.document.body.innerHTML);
Similar problem is at this thread at, but no any solution
http://forums.devarticles.com/javascript-development-22/lock-frame-scroll-42878.html
Expert: Rob Jurd replied at 2024-10-23 16:17:36
125 points GOOD
CKY092 is right however by wrapping the iframe in a div and controlling the scroll css attribute of the DIV you can get the same effect
Expert: CKY092 replied at 2024-10-23 16:14:38
Unfortunately, it doesn't look like you'll be able to use JS to manipulate the scroll attribute with IE.
http://www.w3schools.com/jsref/tryit.asp?filename=tryjsref_iframe_scrolling
Expert: Rob Jurd replied at 2024-10-23 16:07:38
125 points GOOD
I'm not entirely sure of the effect you're after but is this is kind of layout you want? I've removed your frames and replaced with iframes. Was there a reason you wanted a frameset?
<DOCTYPE html><html lang='en'> <title></title> <style type='text/css'> div { overflow: none; } iframe { width: 100%; } #first { height: 250px; } #second { height: 600px; } </style><head></head><body><div id='d1'> <iframe name="myiframe1" id="first" scrolling='no' border='0' frameborder='0' src="http://www.wiki.com" >Does not support iframe</iframe></div><p>Testing frame</p><a href="javascript:scrolltest();">Testing scrolling in frame click<a><div> <iframe name="myiframe2" id="second" scrolling='no' border='0' frameborder='0' src="http://www.yahoo.com" >Does not support iframe</iframe></div></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:
