When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-10-11 06:38:21
Point:0 Replies:6 POST_ID:828529USER_ID:11059
Visual Basic Programming;;Windows XP Operating System
I would like to program code in EXcel2003 VBA to turn on or off my monitor in my window XP
computer and I tried the code in the link, http://www.expertsexchange.com/Programming/Misc/Q_20840222.html
and set lparm in sendmessage API function from 1 or 2, But it doesn't have any response on
my monitor, Why ? lparm=2 is setting to turn off and 1 is setting for turn-on
Is it hwnd handle that can be any window's handle in attached VBA code ? or other setting I need
to set for hwnd input in oder to turn on or off monitor ?
ANd it doesn't work , is it because my montherboard not supporting the function ?
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long Private Const WM_SYSCOMMAND = &H112 Private Const SC_MONITORPOWER = &HF170Sub Monitor()Dim hwnd As Longhwnd = GetForegroundWindow()Call SendMessage(hwnd, WM_SYSCOMMAND, SC_MONITORPOWER, 2)End Sub 1:2:3:4:5:6:7:8:
Author: duncanb7 replied at 2024-10-13 06:55:12
please don't use Net User Administrator /active:no if it is only one account in xp such as only Administrator
and otherwise you will be locked and could not login into computer again besides you need
to reboot the comptuer into safe mode.
THe final solution is
1- type command at command line or run with "control userpassword2s , check the box the
password require during login and then select your account in the account name menu right below
the box that action is for putting your account in first priority or as deafult login name and password
for auto login process , and then uncheck the password require for login box in order to
enable auto login process with your default your login name and password, so next time
you will be automatically logging into Xp without typing your login and password from hiberation mode
2-use rt = SetThreadExecutionState(ES_DISPLAY_REQUIRED) in the VBA code and put the code
into xls's workbook_open() sub in Thisworkbook module and set the xls file as one schedule task to wake up the computer from sleep or hiberation mode and the monitor will be wake up by the setThreadExecutionState()
3-go to start menu/control-panel/power management option/advance tab/ and uncheck the box for password require when computer is wkae up from hiberation mode
Now I can wake my xp computer and also wake up monitor for any other schedule task or program work which must need monitor is on. (Of course most of schedule task program or update is no need monitor on)
Author: duncanb7 replied at 2024-10-13 06:54:35
Expert: dlmille replied at 2024-10-12 08:34:15
You had asked why the Administrator cannot be disabled. Perhaps I misunderstood. I just gave you the command to deactivate Admin login.
Your question is how to autologin as Administrator?
Dave
Dave
Author: duncanb7 replied at 2024-10-12 04:16:10
What you mean if I type command at C:> Net User Administrator /active:no
but, Administrator will be disallowed login as well ?
I am only the user on my computer with window xp, and you
mean "but, Administrator will be disallowed login as well"
that I can not login my comptuer if type Net User Administrator /active:no
at command line.
Just want to auto login to my desktop screen without going through any login box
at command line.
Expert: dlmille replied at 2024-10-11 19:12:32
You can disable Administrator logon with the command prompt:
You should not get an Administrator login option after that - but, Administrator will be disallowed login as well.
Author: duncanb7 replied at 2024-10-11 12:02:42
The problem is solved if using SetThreadExecutionState(ES_DISPLAY_REQUIRED)
and monitor is on once computer is startup from sleep mode, and
logon welcome page can be disabled by controluser account and uncheck welcome page option
but it is still existing Adminstrator logn box even welcome page is gone.
So the final issue is Adminstrator logon box can not be disabled , Why ?
Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Private Declare Function SetThreadExecutionState Lib "kernel32" (ByVal esFlags As Long) As Long
Private Const ES_DISPLAY_REQUIRED = &H2
Private Sub workbook_open()
'Sleep 80000
Dim rt As Long
'for delete welcom login page on xp, just tye at command line, "control userpasswords2"
' for delete adminstrator login message box , read at http://www.ehow.com/how_5959387_stop-logon-startup-win-xp.html
Set WsShell = CreateObject("WScript.Shell")
'Sleep (1000)
'WsShell.Run ("TaskMgr.exe")
'Sleep (5000)
'WsShell.SendKeys ("sea")
'WsShell.SendKeys ("{enter}")
'this.Caption = Hex(rt)
End Sub
'Sleep 80000
Dim rt As Long
'Sleep (1000)
'Sleep (5000)
End Sub
