When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-08-27 03:54:37
Point:500 Replies:5 POST_ID:828526USER_ID:11059
Visual Basic Programming;Microsoft Office Suite;Microsoft Excel Spreadsheet Software
I have 55000 data and need to be plotted in one curve within one plot.
But in excel, it report out just show or allow the limit 32000 data in my chart I created.
Now Can I solve it in Excel 2003 by VBA ?
I try this following VBA code before, but it is not working, just show me two sepearte curves only, how to combine two into one curve with
correct X-axis value ? OR I also need to seperate the x -axis data into two series and combine it one
by vba code ?
Sub Chart()
'Plot Y-axis data from two separate series into one
Dim firstrow as long
Dim lastrow as long
Dim seclastrow as long
firstrow=1
lastrow=20000
seclastrow=55000
ActiveSheet.ChartObjects("Chart 4").Activate
ActiveChart.PlotArea.Select
ActiveChart.SeriesCollection.NewSeries 'need to be delete if create is done
ActiveChart.SeriesCollection(1).Values = "=" & sheetname & "!R" & firstrow & "C8:R" & lastrow & "C8"
ActiveChart.SeriesCollection(2).Values = "=" & sheetname & "!R" & lastrow+1 & "C8:R" & seclastrow & "C8"
End Sub
by vba code ?
Sub Chart()
Dim lastrow as long
firstrow=1
lastrow=20000
seclastrow=55000
End Sub
Author: duncanb7 replied at 2024-08-27 10:01:00
Finally, I take teylyn's suggestion, take less data into
chart by half.
maybe take even row data since some adjcent data
is similar.
Thanks for all of you reply
chart by half.
is similar.
Expert: byundt replied at 2024-08-27 08:25:31
100 points EXCELLENT
The limit in Excel 2003 is 32,000 points per series, and 256,000 points per chart. Your code was failing because you tried to make the second series with 35,000 points.
I revised your code to avoid that pitfall and to use the same marker color. The code assumes that the X-values are in column A and that all the data is on worksheet Sheet2.
Sub Chart()'Plot Y-axis data from two separate series into oneDim firstrow As LongDim lastrow As LongDim seclastrow As LongDim sheetname As StringDim ser As SeriesApplication.ScreenUpdating = Falsesheetname = "Sheet2"firstrow = 1lastrow = 25000seclastrow = 55000With ActiveSheet.ChartObjects("Chart 4").Chart If .SeriesCollection.Count < 1 Then .SeriesCollection.NewSeries 'need to be delete if create is done .SeriesCollection(1).XValues = "=" & sheetname & "!R" & firstrow & "C1:R" & lastrow & "C1" .SeriesCollection(1).Values = "=" & sheetname & "!R" & firstrow & "C8:R" & lastrow & "C8" .SeriesCollection(1).MarkerForegroundColorIndex = 4 If .SeriesCollection.Count < 2 Then .SeriesCollection.NewSeries .SeriesCollection(2).XValues = "=" & sheetname & "!R" & (lastrow + 1) & "C1:R" & seclastrow & "C1" .SeriesCollection(2).Values = "=" & sheetname & "!R" & (lastrow + 1) & "C8:R" & seclastrow & "C8" .SeriesCollection(2).MarkerForegroundColorIndex = 4End WithEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:
Brad
Expert: Saqib Husain, Syed replied at 2024-08-27 04:14:59
But then unless this is an xy scatter graph the two series would overlap
Expert: Saqib Husain, Syed replied at 2024-08-27 04:11:47
I see that you do not have sheetname defined. Either define it or replace it with
activesheet.name
activesheet.name
Expert: teylyn replied at 2024-08-27 04:10:28
400 points EXCELLENT
Hello,
In Excel 2003, the limit for data points in a 2D chart is 32,000. In Excel 2010, the limit is determined by the available memory.
In any case, a chart with more than 32,000 data points will make it impossible to identify an individual data point. The rendered chart would have to be a mile wide to make individual data points distinguishable. So, what's the point of trying to include more than 32,000 data points, if they will not be distinguishable in the first place?
Have you considered creating an aggregation of the data and not plot EVERY data point, but ever nth point instead (like every 10th value, or every 100th value)?
cheers, teylyn
cheers, teylyn
