When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by ahowe42
at 2024-08-26 04:29:30
Point:0 Replies:13 POST_ID:828525USER_ID:11360
Microsoft Excel Spreadsheet Software;;Microsoft Access Database
I have a spreadsheet with a table that's linked to an Access database
. The spreadsheet is part of an application, and is distributed to several people. Now, generally, refreshing the table works perfectly. On one person's computer, however, when the table is refreshed, some of the columns change their order so that it is different than what is specified in the query. This screws up lookups that depend on this table.
Out of more than 10 users, only one has this problem. We recently uninstalled, then reinstalled MS Office completely for her. Anybody have ideas?
Andrew
Andrew
Author: ahowe42 replied at 2024-10-05 03:07:04
As an act of desperation, noting that it only happened with a single user, we created a new AD account for her, and it worked fine. The original account had all the same correct permissions, and we have no idea what the problem was. However, it's solved now. Thanks for the help everyone.
Andrew
Andrew
Author: ahowe42 replied at 2024-10-05 03:05:57
Andrew
Andrew
Expert: duncanb7 replied at 2024-09-18 02:45:58
Try to look for in google for Digital Certificate for Macro or Aplication or http://msdn.microsoft.com/en-us/library/aa141471(v=office.10).aspx
It might be Security issue on the your Excel application or sheet, so other users might
not get the most of your update .
Hope it help
Hope it help
Author: ahowe42 replied at 2024-09-14 23:23:39
Nobody really has any ideas about Excel's behavior here?
Andrew
Andrew
Author: ahowe42 replied at 2024-09-03 08:58:02
Nothing is changing in MS Access - it's existence is irrelevant to the issue at hand. What is changing is the order of the columns in the Excel data table. If I refresh the data table on my PC (or any of the others) there is no problem. The columns are ordered as in the query. If I refresh it on her PC, the column order changes.
Andrew
Andrew
Expert: Jeffrey Coachman replied at 2024-09-03 08:22:21
<As I ststed, the user has nothing to do with it...>
Well, you actually stated this:
<but you can never underestimate users, can you?>
So it was not inherently clear to me if this meant it was, or was not a user issue, or if you were not sure.
JeffCoachman
JeffCoachman
Author: ahowe42 replied at 2024-09-03 02:22:42
Andrew
Andrew
Expert: Jeffrey Coachman replied at 2024-09-03 02:12:07
That's why I asked...
If the user can change the Column Order, then there really is no solution other option than to not allow them Access to the columns directly.
Again, if it is just this one user and everything else about their setup is the same as the other users, then it would point to the user...
The issue is where are the columns being changed?
In Access or in Excel?
Author: ahowe42 replied at 2024-09-03 01:26:14
No progress on a solution.
Expert: Jeffrey Coachman replied at 2024-09-02 18:07:04
OK, so where do we stand on his...?
Author: ahowe42 replied at 2024-09-02 10:02:39
mann: I know I can do that, but I need to figure out the problem, in case there's something else affected I've not seen yet.
jeff: yep, but you can never underestimate users, can you?
Andrew
Andrew
Expert: Jeffrey Coachman replied at 2024-08-26 09:33:15
Not sure either...
Are you quite sure that the user is not changing the column order?
JeffCoachman
JeffCoachman
Expert: mannhardt replied at 2024-08-26 05:23:37
Hi Andrew,
I don't have any clue what the reason might be for the column mixing behaviour, but perhaps I can offer you a workaround. Do not use VLOOKUP, use INDEX based on the column labels. Check if this example works for you.
