When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-27 11:06:26
Point:500 Replies:12 POST_ID:828520USER_ID:11059
Hypertext Markup Language (HTML);Visual Basic Programming;Windows XP Operating System
I try to use VBA in Excel 2003 to do myie.navigate a link in IE7 and the code is attached as code area
The target is first create IE object and then navigate "www.yahoo.com" and then
create new instance within the same IE window browser just created , and then navigate "www.wiki.com"
in second instant just created and finally navigate "www.microsoft.com" in the same second intance that just navigated "www.wiki.com" at the same IE browser
But the code is NOT good, www.micorsoft.com page is navigated into the first instance with "www.yahoo.com" instead
of the instance of www.wiki.com, So I try to force it happen, so I use myie.navigate "http://www.microsoft.com", Clng(navOpenInBackgroundTab) but it is same going into the first instance. How to control the navigate on the any instance
I want with in same IE browser ?
Please advise with link http://msdn.microsoft.com/en-us/library/aa768360(v=VS.85).aspx
Sub test()Const navOpenInNewTab = &H800Const navOpenInBackgroundTab = &H1000,Dim myie As SHDocVw.InternetExplorerSet myIE = CreateObject("InternetExplorer.Application")Set myIE = New InternetExplorerWith myIE .Top = 10.Left = 1900.Height = 800.width = 1050 .Visible = True.navigate "http://www.yahoo.com"calling waiting(myie,1) "just simple waiting for IE loading is done.navigate "http://www.wiki.com", clng(navOpenInNewTab) ' Create new Instance and naivgatecalling waiting(myie,1)''''Try to navgiate into other website on the instance which just navigate "www.wiki.com".navigate "http://www.microsoft.com",Clng(navOpenInBackgroundTab),calling waiting(myie,1)End withEng SubFunction WAITING(ByRef myIE As SHDocVw.InternetExplorer, ByRef state As Integer)Dim b As VariantWith myIEb = Time()On Error GoTo L1Do Until Not .Busy And .readyState = READYSTATE_COMPLETE Or TimeValue(Time()) - TimeValue(b) > TimeValue("00:00:15")Loop If Not .Busy And .readyState = READYSTATE_COMPLETE Then DoEvents state = 0 Else state = 1 End If End WithL1:End Function 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:
Expert: Qlemo replied at 2024-08-07 02:37:31
I now see I completely misunderstood the question, not reading thoroughly thru it ...
Expert: Ark replied at 2024-08-06 23:21:42
>>what the major change <<
For Each w In wins
For Each w In wins
Expert: Qlemo replied at 2024-08-06 09:29:00
Ark,
Please explain what the major change is which makes your code work for duncanb7.
Author: duncanb7 replied at 2024-08-06 09:03:43
Thanks for all of you reply, Ark's code is
doing what I exactly expect
Expert: Ark replied at 2024-08-04 15:11:15
450 points EXCELLENT
Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)Const navOpenInNewTab = &H800Const navOpenInBackgroundTab = &H1000Sub test2() Dim myIE As shdocvw.InternetExplorer Set myIE = CreateObject("InternetExplorer.Application") Set myIE = New InternetExplorer With myIE .Top = 10 .Left = 1900 .Height = 800 .Width = 1050 .Visible = True End With TabNavigate myIE, "NewWindow", "http://www.yahoo.com" TabNavigate myIE, "NewTab", "http://www.wiki.com"''''Try to navgiate into other website on the instance which just navigate "www.wiki.com" TabNavigate myIE, "http://www.wiki.com", "http://www.microsoft.com"End SubFunction TabNavigate(ie As shdocvw.InternetExplorer, tabUrl As String, newUrl As String) If tabUrl = "NewTab" Then ie.Navigate2 newUrl, 4096 WaitComplete ie Exit Function ElseIf tabUrl = "NewWindow" Then ie.Navigate2 newUrl WaitComplete ie Exit Function End If Dim wins Set wins = New shdocvw.ShellWindows For Each w In wins If Len(w.LocationURL) >= Len(tabUrl) Then If Left$(UCase(w.LocationURL), Len(tabUrl)) = UCase(tabUrl) Then w.navigate newUrl WaitComplete w Exit For End If End If NextEnd FunctionPrivate Sub WaitComplete(ByVal wb As Object) Dim counter As Integer On Error GoTo ExitWait Do While wb.readyState < 4 DoEvents Sleep 100 counter = counter + 1 If counter > 100 Then Exit Do LoopExitWait:End Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:
Expert: Qlemo replied at 2024-08-04 12:59:50
Checked on Vista IE9 - and it works, three tabs open. I assume it is a timeing issue, but cannot see how that should happen using your Waiting sub ... But you could add another delay (e.g. by not leaving the loop, so force-waiting 15 seconds) to test for that.
Author: duncanb7 replied at 2024-08-03 12:05:04
Copy wrong code in the wrong module in VBA
And I think it might not be your problem, do you think we need to change some
setting in IE option-->internet option->Advance,
I try to uncheck or check those related instance matter, it is not any changge to
the VBA code
the VBA code
Expert: Qlemo replied at 2024-07-31 12:21:15
Still got the same errors:
calling is not a valid statemend
eng sub should be end sub
which tells me you cannot have tested that. Call me nit-picking, but your test must be proven wrong for me to be right ;-). Seriously, I need to have exactly the same code as you.
Author: duncanb7 replied at 2024-07-31 12:12:43
Sub test()
With myIE
.Top = 10
.Left = 1900
.Height = 800
.width = 1050
.Visible = True
.navigate2 "http://www.yahoo.com"
.navigate2 "http://www.wiki.com", 4096 ' Create new Instance and naivgate
.navigate2 "http://www.microsoft.com", 4096
End with
Eng Sub
Dim b As Variant
With myIE
b = Time()
On Error GoTo L1
Loop
DoEvents
state = 0
Else
state = 1
End If
End With
L1:
End Function
With myIE
.Top = 10
.Left = 1900
.Height = 800
.width = 1050
.Visible = True
End with
Eng Sub
Dim b As Variant
With myIE
b = Time()
On Error GoTo L1
Loop
DoEvents
state = 0
Else
state = 1
End If
End With
L1:
End Function
Expert: Qlemo replied at 2024-07-31 05:45:37
Please provide you actual code. The above posted has many compile errors.
Author: duncanb7 replied at 2024-07-31 05:09:58
still not working
just opening three new instance , so total is 4 inclduing www.google.co.uk
Tagert is doing navigate within 2 instance only, last three link will goto the last instace of two instance
Expert: Qlemo replied at 2024-07-27 12:40:37
50 points EXCELLENT
Use .Navigate2 instead of .Navigate. Ie.
.Navigate2 "http://www.google.co.uk"
.Navigate2 "http://www.google.cz", 4096
.Navigate2 "http://www.google.cn", 4096
.Navigate2 "http://www.google.it", 4096
(no wait in-beween necessary!) will open for tabs.
