When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-04-30 13:08:40
Point:250 Replies:9 POST_ID:828493USER_ID:11059
Linux;;Windows XP Operating System
Recenly I have reinstalled my Window XP notebook . and I find something it is different before using Window Vista.
When I do editing using my keyboard like I am writing this thread to you. I could not type too fast , otherwise
the edit cursor/point will shift other line or other area.
For example,
If I type in fast typing speed for the following sentence
" I am typing some word to EE exchange expert and please give me advice"
it will become
" I EE exchange expert and am typing some word to ...."
Until I stop any writing after the word of expert" and I need to correct those incorrect postion typing or editing
So everytime, I need to care my speed typing, No matter on what editor I am using also find similar problem like editing
in Notepad or Notepad++ etc... The keyboard cursor always shfit and I need to repostion to correct area or position if typing too fast
So now I will type it really slow to prevent those typing shfiting , And I also put a soft cover under my mouse so that it won't
let the mouse easily to be moved or shift when I typing too fast, it help a little bit but not completely.
What is wrong with my keyboard speed on my Window XP, Is there some setting on XP can ajust the keyboard speed and key sensitivity
For example,
it will become
Author: duncanb7 replied at 2024-05-16 22:27:21
Thanks for your reply
Expert: huacat replied at 2024-05-01 08:24:36
250 points GOOD
I also meet this issue before. I'm using Dell XPS M1530.
After I disable the touchpad function "tap for click", I solve it!
Most touchpad enable the user tap the pad to generate a left mouse button click event.
But maybe the we misoperator.
I think you can adjust the settings via control panel, mouse settings. Good luck!
Author: duncanb7 replied at 2024-05-01 00:49:02
It is Samsung R20 Plus Dual core Intel T5550 CPU 1.83GHz
Expert: megaman5 replied at 2024-04-30 14:37:01
What model of laptop do you have so I can find you the shortcut key.
Author: duncanb7 replied at 2024-04-30 13:29:31
Any suggestion, please help, now just typing too fast and too slow might not be good
"Too Fast for what and Too Slow for what" These question I think is seldom or rare
Author: duncanb7 replied at 2024-04-30 13:27:49
I tried a lot of method, but it doesn't help too mcuh within these two month, since
I am hurry to send email so I just let it typing in slow speed
Author: duncanb7 replied at 2024-04-30 13:26:32
Putting a soft cover under the mouse is better but not completely
So it might related to keyboard and mouse issue
Author: duncanb7 replied at 2024-04-30 13:23:15
Could I turn-off my mouse ?
What is exact command FN+?
Expert: megaman5 replied at 2024-04-30 13:21:11
Are you accidently touching the touch pad? Can you turn that off with a hot key (Fn+something)?
