When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-04-26 08:05:39
Point:250 Replies:5 POST_ID:828486USER_ID:11059
Hypertext Markup Language (HTML);;PHP Scripting Language
I would like to ask two question:
1-How to suppress the Warning such as "Warning: DOMDocument::loadHTMLFile() [domdocument.loadhtmlfile]: htmlParseEntityRef: expecting ';' in http://www..............on Line 20" since it is more than 100 for such warning.
I don't find any option from man php command in Linux for switch-off the warning message . Any solution ?
2- how to make s simple script to re-run the php command once it has fatal error , any informatiion for that ?
Author: duncanb7 replied at 2024-04-27 06:22:52
Thanks for your reply,
The second question might
go to new thread
go to new thread
Expert: Rob Jurd replied at 2024-04-26 22:31:23
see here in the manual. the "@" is used to suppress error and warning messages
http://au.php.net/manual/en/language.operators.errorcontrol.php
Author: duncanb7 replied at 2024-04-26 22:03:10
@, what is that mean? it works fine as you suggest, Why ? Please explain a little bit.
Expert: Rob Jurd replied at 2024-04-26 21:51:49
If you want to suppress output warnings from loadHTMLFile($url), put an @ sign in front. This even works in:<?php$load = @$dom->loadHTMLFile($url);?> 1:2:3:4:
Expert: Ray Paseur replied at 2024-04-26 21:50:55
Can't help you with number two - I've never wanted to design an app around tolerance for a fatal error. But for the first one, you can use the @ notation:
Something like this...
$thing = @file_get_contents($url);
if ($thing === FALSE) echo "$url DID NOT WORK OUT WELL BUT WE SUPPRESSED THE ERROR";
