When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by awesomejohn19
at 2024-04-25 09:27:47
Point:500 Replies:8 POST_ID:828485USER_ID:11311
Microsoft Excel Spreadsheet Software;;Visual Basic Programming
I want to write formulas with vba on a spreadsheet. I couldnt make the following work.
So there is a for statement which is supposed to from j=0 to 10. So on each ("C10"), I would like to write the formula ("C11").offset(0,j)/("C7").offset(0,j). So again, I dont want the exact number but I would like to have the formula on that cell ("C10")
I tried the following but it doesnt work.
Sheets("Sheet3").Range("C10").Offset(0, j).Formula = "=(Sheet3!C"&," & Sheets("Sheet3").Range("C11").Offset(0, j).Value & "/" & Sheets("Sheet3").Range("C7").Offset(0, j).
Expert: bromy2004 replied at 2024-06-08 01:20:51
VBA Example-1
Set rg = Cells(1, m.Column)
Set rg = Range(rg, Cells(l1000, rg.Column))
rg.Offset(0, 0).FormulaR1C1 = "=if(rc[" & l.Column - p.Column & "]>0,rc[" & l.Column - m.Column & "],0)"
Example-2
range("A1")= "=" & sheetname & "!R" & firstrow & "C4:R" & lastrow & "C4"
range("A2") = "=" & sheetname & "!R" & firstrow & "C2:R" & lastrow & "C2"
You can switch A1,B1, to RC in your excel shhet from tool--> option-->Genernal
Example-2
Expert: bromy2004 replied at 2024-06-03 18:24:17
VBA Example-1
Example-2
Example-2
Expert: duncanb7 replied at 2024-05-05 11:43:27
VBA Example-1
Example-2
Example-2
Expert: Rory Archibald replied at 2024-04-26 00:16:27
You could also use R1C1 style:
Sheets("Sheet3").Range("C10").Offset(0, j).FormulaR1C1 = "=R[1]C/R[-3]C"
Expert: damerval replied at 2024-04-25 11:53:17
You write "on each C10". There is only one C10. Am I understanding correctly that you want to set formulae horizontally from left to right, updating the column letter as you move to the right? It is easiest to manually drag the formula on the far left , excel will automatically fill cells to the right accordingly, updating the formula as it goes. To do this in code, try something like this (using the integer values for the column letters):
For Col = Asc("C") To Asc("D")
Sheets("Sheet1").Range(Chr(Col) & "10").Formula = "=" & Chr(Col) & "7/" & Chr(Col) & "11"
Next Row
Next Row
Author: awesomejohn19 replied at 2024-04-25 11:41:48
Ok, this worked
Sheets("Sheet3").Range("C10").Offset(0, j).Formula = "=" & Sheets("Sheet3").Range("C11").Offset(0, j).Address & "/" & Sheets("Sheet3").Range("C7").Offset(0, j).Address
Author: awesomejohn19 replied at 2024-04-25 11:24:14
Thanks for your response. Are you sure this is correct? When I do this I will get someting like C11.offset(0,J) which doesnt seem to be a valid worksheet function. When I type this I get #Name (I use C11.offset(0,2) for example. But what I need is just C11/C7. then D11/D7 for example.
Maybe I didnt understand what you mean completely. I am little confused :)
Expert: damerval replied at 2024-04-25 10:13:48
You have the right idea with the formula property. However, you need to set it as a string, which means that if your string contains double quotes, you need to double them up like this ("") so that they end up as double quotes in your string. Something like this:
Formula = "(""C11"").offset(0," & j & ")/(""C7"").offset(0," & j & ")"
HTH
Philippe
HTH
Philippe
