When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-04-15 08:30:51
Point:500 Replies:10 POST_ID:828476USER_ID:11059
JavaScript;;
I try test the $"('mainFrame').load() in Jquery with following javascript code for
testing whether the mainframe of frame is loaded and then falert box is coming out
for "frame window loaded" But it fail, only .ready alert box is coming for " frame document ready"
Why, whatis wrong with my code ? and I check firebug there is no any error
I have use before $(document).load() and $document).load() , it works fine but it will waiting
all three frame pages are loaded toegether the message abert will happen but I want
to check whether the specified frame window is load by $('#mainFram').load().
I already check the id and name of frame is same as "mainFrame"
<!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8"> <title>jQuery demo</title> </head> <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.5/jquery.min.js"></script><script type="text/javascript"> $('#mainFrame').ready(function() { alert(" frame document is ready");}); $('#mainFrame').load(function() { alert("frame window is loaded");});</script><frameset rows="45, 100,*" cols="*"><frame id="flashFrame" name="flashFrame" marginwidth=0 marginheight=0 frameborder="no" scrolling="NO" src="/kflash.html"><frame id="myFrame" name="topFrame" frameborder="no" scrolling="NO" src="/box.html"><script language="javascript"> document.getElementById("myFrame").noResize = true;</script><frame id="mainFrame" name="mainFrame" marginwidth=0 marginheight=0 src="http://www.mydomain.com/test.html" frameborder="no" ></frame></frameset></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:
Author: duncanb7 replied at 2024-04-20 01:19:39
Thank for your reply,
it work for my website
for example
www.mywebsite.com
www.yahoo.com works
but it is not for all .html extentsion file for Jquery's load() such as www.mywebsite.com/test.html
Expert: roma1123 replied at 2024-04-16 04:24:12
<body onload=test()"> - there is an error here. it should be like this:
<body onload="test()">
also, note window.onload will throw errors in Firefox
Author: duncanb7 replied at 2024-04-15 13:16:08
but it is same for window.onload..
So in my test.html is nothing insdie beside those tag and html and body ,div etc.
Author: duncanb7 replied at 2024-04-15 13:06:19
<body onload=test()">, it might be problem here on onload because I delete all fucntion running in test() function.
So I might switch to window.onload to see any help
Author: duncanb7 replied at 2024-04-15 12:37:14
Even I quit the firefox and try again becasue of Cahce issue, but it is same
Author: duncanb7 replied at 2024-04-15 12:36:32
there is no any bug from firebug I have checked many times
No alert message for frame widnow is in FIrefox, IE, Safari.
So I believe it is related to the xmlhttp.request. Any suggestion
Expert: roma1123 replied at 2024-04-15 12:34:07
you most probably have an javascript error on test.html page which is preventing your alert to appear.
Check that page for javascript errors.
Author: duncanb7 replied at 2024-04-15 12:28:27
Alert message for frame window is coming out for www.yahoo.com but not for my test.html, Why ?
Author: duncanb7 replied at 2024-04-15 12:23:27
You are right,
When it go to other website , it work correctly such as www.yahoo.com
<frame id="mainFrame" name="mainFrame" marginwidth=0 marginheight=0 src="http://www.yahoo.com" frameborder="no" >
But for my test.html the alert("frame windows is loaded") is NOT coming out even I have seen
all page is loaded.
In test.html is extract a table from using xmlhttp to open a csv file and then use string.push to
do a string and put it the tag id by getelementby id<"div"). even I change the size of table to be 1*1 that
is no alert message box for frame window is loaded. Please review my code.. Is it Jquery confict to
xmlhttp request ? Everything is loaded and table is well done but no alert message for frame window
all page is loaded.
function getData( url ,k){var xmlhttp;if (window.XMLHttpRequest) {// code for IE7+, Firefox, Chrome, Opera, Safari xmlhttp=new XMLHttpRequest(); }else {// code for IE6, IE5 xmlhttp=new ActiveXObject("Microsoft.XMLHTTP"); } xmlhttp.onreadystatechange = function() { if ( xmlhttp.readyState == 4 ) { // alert("Waiting render"); inner2( xmlhttp.responseText );//alert("render finsh"); } } xmlhttp.open( "GET", url, true ); xmlhttp.send( null );}function inner2(data){ var y=0; var k=123;var dataRows = data.split( "" ); removeTable(); var time1 = new Date().getTime(); var string = new Array(); string.push('<table>');//string.push(''); columnwidth(string); string.push('<tbody>');try { for (var i=0;i<1;i++) { var dataCells = dataRows[i].split(","); string.push('<tr>'); for (var j=0;j<dataCells.length; j++) { y='<td>'+ dataCells[j] + '</td>'; //string.push('<td>*</td>'); //string.push('<td>12</td>'); //string.push('</td>'); string.push(y); } string.push('</tr>'); } }catch(err) {} string.push('</tbody></table>'); var writestring = string.join(''); document.getElementById('writeroot').innerHTML = writestring; //var time2 = new Date().getTime(); //doTiming(5,time1,time2); columnstyle();}function test () { getData("http://www.mywebsite/javascript.csv?r=1264",0 );}// --></script><body onload=test()"><div id=writeroot" ></div></body></div> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:
Expert: roma1123 replied at 2024-04-15 11:10:06
I think your frame has not yet loaded and you must attach load event inisde a .ready();. Like this:
<!DOCTYPE html> <html lang="en"> <head> <meta charset="utf-8"> <title>jQuery demo</title> </head> <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.5/jquery.min.js"></script><script type="text/javascript"> $('#mainFrame').ready(function() { alert(" frame document is ready"); $('#mainFrame').load(function() { alert("frame window is loaded"); });});</script><frameset rows="45, 100,*" cols="*"><frame id="flashFrame" name="flashFrame" marginwidth=0 marginheight=0 frameborder="no" scrolling="NO" src="/kflash.html"><frame id="myFrame" name="topFrame" frameborder="no" scrolling="NO" src="/box.html"><script language="javascript"> document.getElementById("myFrame").noResize = true;</script><frame id="mainFrame" name="mainFrame" marginwidth=0 marginheight=0 src="http://www.mydomain.com/test.html" frameborder="no" ></frame></frameset></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:
