When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-04-15 06:44:27
Point:125 Replies:7 POST_ID:828475USER_ID:11059
Windows XP Operating System;;
Mostly likely we will do backup fromour D: or C: to external USB drive such as F:
and we will copy it in the my computer icon.But sometimes might be we are
not careful, we copy it from F: to D:. Is ther windows system let us a message
box to confirm the direction copy in XP ? Is there any setting we can make for
just one direction copy always during this time period
THanks
THanks
Author: duncanb7 replied at 2024-04-16 11:51:39
Thanks for yoru reply, ir works
Expert: Randy Downs replied at 2024-04-15 06:54:31
42 points EXCELLENT
Here is an article on vbscript if you prefer - http://social.technet.microsoft.com/Forums/en-US/ITCG/thread/874d303f-f201-4fee-ad47-4f7c8979434f/
Expert: Randy Downs replied at 2024-04-15 06:52:18
41 points EXCELLENT
You could do something like this and even automate it through scheduler.
http://theos.in/news/windows-xp-batch-file-script-to-copy-all-files/
Author: duncanb7 replied at 2024-04-15 06:51:56
if vbscript is also welcome
Author: duncanb7 replied at 2024-04-15 06:51:21
I am not familar with bat file, could you provide a little code to start.
Expert: Randy Downs replied at 2024-04-15 06:49:55
I am guessing you are doing a copy & paste for your backup. It would be easier to control from a script ?
Expert: bcreech replied at 2024-04-15 06:48:22
42 points EXCELLENT
One way to do this would be to eliminate human interaction. write a batch file of vbscript file that the user clicks on, and it runs the copy routine.
