When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-03-28 12:47:48
Point:250 Replies:10 POST_ID:828456USER_ID:11059
Outlook Groupware Software;Visual Basic Programming;Microsoft Office Suite
I would like to send webpage inside the email to my client by VBA outlook 2003.
Now I just know how to send email in text format as follow simple code attach
I mean Client will receive the email to view the webpage inside the email no need to
re-open IE or no need click the href link to view to view the web page
Please advise and provide a little code for send web page through email sent in Outlook 2003 VBA
Function sendmail()Set app = CreateObject("outlook.application")Set itm = app.CreateItem(0)Application.DisplayAlerts = FalseWith itm.Subject = "dail report".To = "duncanuk9@hotmail.com.hk".Body = "daily last report"'.Display.Send End WithSet app = NothingSet itm = NothingEnd Function 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:
Author: duncanb7 replied at 2024-03-31 08:04:37
>>>>it works but some ISP email box could not display the wbepage , Why?
Probably it is blocked by the system administrator?
>>>>I use .htmlbody that is similar to .body , Why ?
I suggested .htmlbody for a different reason. I am not sure if you can use that here.
Sid
Sid
Expert: SiddharthRout replied at 2024-03-30 10:17:11
Sid
Sid
Author: duncanb7 replied at 2024-03-30 10:04:59
Author: duncanb7 replied at 2024-03-30 10:04:09
and if we can .htmlbody in VBA is same as your suggestion web site
Expert: SiddharthRout replied at 2024-03-29 14:27:13
I am not sure you can do it via code but I think this is what you want?
Title:Viewing Web Pages in Outlook
Link: http://h10076.www1.hp.com/education/demo/Outlook/ol-intro/webpage.htm
Sid
Sid
Author: duncanb7 replied at 2024-03-29 08:45:01
Any suggestion ? Please advise kindly
Author: duncanb7 replied at 2024-03-29 06:12:54
Yes,
Expert: SiddharthRout replied at 2024-03-29 04:21:05
Author: duncanb7 replied at 2024-03-29 03:58:13
For example, www.yahoo.com
.htmlbody="http:www.yahoo.com"
Is it correct ? But I fail, it just send the path of link
Expert: SiddharthRout replied at 2024-03-29 03:35:48
Instead of .Body, you will have to use .HtmlBody :)
Can you give more details of this web page that you want to send?
Sid
Sid
