When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-03-27 01:53:42
Point:500 Replies:2 POST_ID:828451USER_ID:11059
Web Browsers;Apple Software;Visual Basic Programming
Usually, I am using IE broswer for my internet work and using the folllowg VBA code
to access any website in IE. Now I would like to siwtch to Apple Safafi browser since its speed
THe question how to convert the following VBA code such as dim myie as SHDocVw.InternetExplorer,
IE.navigate ,etc for Safafi and Firefox broswer.
Please kindly provide a simple hint code for that
DUncan
DUncan
Sub login()dim myie as SHDocVw.InternetExplorerSet myie = CreateObject("InternetExplorer.Application")Set myie = New InternetExplorerhdlg = 0With myie .Top = 10.Left = 1900.Height = 800.width = 1050 .Visible = True.navigate "www.yahoo.com"End withEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:
Author: duncanb7 replied at 2024-04-10 15:47:46
Thanks for your reply,
Expert: radugpopa replied at 2024-03-27 03:45:59
The problem is that Firefox or Safari is not a Microsoft application, so you cannot instance them as you do with Internet Explorer. However the below code might help you achieve what you need:
Function OpenURL(URL as String) As Double
OpenURL = Shell(""C:Program FilesMozilla Firefoxfirefox.exe " & URL)
End Sub
End Sub
