When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-03-23 07:46:36
Point:500 Replies:7 POST_ID:828448USER_ID:11059
Hypertext Markup Language (HTML);Visual Basic Programming;Microsoft Excel Spreadsheet Software
I would like to have a good example website to show how it will have code speed advantage
for Application.Calculation = xlCalculationManual and Application.Calculation = xlCalculationAutomatic
I know those functionality but I wonder what situation we will use it individually for speed ?
Aud during file save, Is it all formula in Excel sheet will be updated even I set it xlCalculationManual ?
Duncan l
Duncan l
Author: duncanb7 replied at 2024-03-26 06:13:35
>> In what situation, Application.CalculateBeforeSave = False,is good for speed optimization ?
As I mentioned before, it would really make a difference if you have a file with huge volume of data and a lot of formulas. It really differs from sheet to sheet. Say for example, more than 1000 rows of data and 3 columns have formulas in it...so there are 3 * 1000 = 3000 formulas that excel needs to calculate would obivously slow down editing the spreadsheet.
but without looking at the data, you need to make an educated guess on it...
Expert: pari123 replied at 2024-03-25 12:29:42
Author: duncanb7 replied at 2024-03-25 12:21:08
Dear pari123,
Thanks for your suggestion ?
But my question, even I don't know
In what situation, xlcalcaulteManual is good for speed optimization ? or what Is said above is correct
(THe function might be good when you are doing a VB code debugging or doing a code for sepcifiy sheet from that you
don't want to recaulate other sheets since other sheets value is not important at this moment )
Expert: pari123 replied at 2024-03-25 12:11:53
Hi Duncan,
If you use the following code -
Private Sub Workbook_Open()Application.Calculation = xlCalculationManualApplication.CalculateBeforeSave = FalseEnd Sub 1:2:3:4:5:
then this doesn't recalculate while saving.
Application.CalculateBeforeSave = Values are True or False. If calculation is Manual and CalculateBeforeSave is true when you Save the workbook it will be recalculated.
Author: duncanb7 replied at 2024-03-25 11:55:53
If recaulation before save ,So it might not help me if my VBA code needs to do open file and save file for automation looping 100 files.
AM i right ?
AM i right ?
Expert: Saqib Husain, Syed replied at 2024-03-23 12:25:39
I think formulas are recalculated before save
Saqib
Saqib
Expert: pari123 replied at 2024-03-23 08:15:17
if you search in experts-exchange, you can find good articles about this. THere is also a write-up on C Pearson's site.
Here's the link - http://www.cpearson.com/excel/optimize.htm
From my experience, the advantage to set it xlCalculationManual is if when your data is huge and there are a lot of formulas.
If the xlCalculationManual is set to manual, it won't update on file save.
Let me know if you need any further clarifications,
Thanks,
Ardhendu
Thanks,
Ardhendu
