When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-12-12 09:44:04
Point:500 Replies:9 POST_ID:828440USER_ID:11059
Visual Basic Programming;Microsoft Access Database;Microsoft Excel Spreadsheet Software
I try to use VBA in Excel Querytable function to extract stock table from yahoo for Web Query Table tutorial
The VBA code I write 's result is not stable at all, sometimes, it can be extracted but sometimes not and
sometimes, have run-time error 1004, sometimes not, really fuzzy...
QUestion-1 Just want to know is it the table too big to be exracted in query from my URL,
sconn = "URL; http://finance.yahoo.com/q/hp?s=%5EDJI&d=11&e=12&f=2010&g=d&a=9&b=1&c=1928&z=66&y=" & i * 66
where i is integer from 0 to 8 ? How can I set max buffer size for query table and loading timeout time
in order to solve my issue if buffer size and timeout time is root cause?
Question-2, If possible, could you help to try my code at your side to see whether my IE or system setting to cause
the problem. I am using IE7 and windows vista ,excel2003?
Question-3, how to use .name with querytable.add, Is it also related to my problem?
Option ExplicitPrivate Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)Sub Yahoostock()Dim i As IntegerDim qtb As QueryTableFor Each qtb In Sheets("data").QueryTablesqtb.DeleteNextRange("A1:z2000").SelectSelection.ClearRange("A1").SelectErr.Cleari = 0Do Until i = 8Dim sconn As Stringsconn = "URL; http://finance.yahoo.com/q/hp?s=%5EDJI&d=11&e=12&f=2010&g=d&a=9&b=1&c=1928&z=66&y=" & i * 66Debug.Print sconnWith ActiveSheet.QueryTables.Add(Connection:=sconn, Destination:=Range("a" & (1 + i * 67))) ' .Name = "Quote: " & symb .FieldNames = True .RowNumbers = False .FillAdjacentFormulas = False .PreserveFormatting = True .RefreshOnFileOpen = False .BackgroundQuery = True .RefreshStyle = xlOverwriteCells .SavePassword = False .SaveData = True .AdjustColumnWidth = False .RefreshPeriod = 0 .WebSelectionType = xlSpecifiedTables .WebFormatting = xlWebFormattingNone .WebTables = "15" .WebPreFormattedTextToColumns = True .WebConsecutiveDelimitersAsOne = True .WebSingleBlockTextImport = False .WebDisableDateRecognition = False .WebDisableRedirections = False ' On Error Resume Next ' .Refresh BackgroundQuery:=False .Refresh BackgroundQuery:=False ' Sleep (5000)End Withi = i + 1LoopEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:
Attachment:yahoodow.xls
Author: duncanb7 replied at 2024-12-15 06:39:42
Thanks, Qlemo, your reply trigger me to think more forwards,
The code is completely working, if the number of time or times to refresh is too long and still failed I can ue
ontime to check as follows. Hope this thread help others who got similar issue
Sub CheckQueryRefreshState(qtbl As QueryTable)
If qtbl.Refreshing Then
'If the query is still refreshing, call the
'CheckQueryRefreshState again in one second.
Application.OnTime Now() + TimeValue("00:00:01"), _
"CheckQueryRefreshState"
Else
'Display the number of rows returned to the query table
'after the query table is refreshed.
MsgBox qtbl.ResultRange.Rows.Count & " Rows Returned"
End If
End Sub
Else
End If
End Sub
Author: duncanb7 replied at 2024-12-15 06:33:47
The issue is came from .refresh from VBA or windows is too short, so sometimes it is work sometimes not .
If we are not able to change register for timeout of refresh or (readystate for navigate web). We can
force the query table to re-do once refresh is fail until is refresh. I think re-do a few time, at least once
is working
is working
Expert: Qlemo replied at 2024-12-15 06:32:48
1. You are missing the goto label Redo
2. It would be much better to check the Err instead of the cell contents to find out there has been an error
3. Either you miss a On Error Goto 0 after the refresh, or should move the On Error Resume Next out of the loop.
Author: duncanb7 replied at 2024-12-15 06:29:51
Else
End If
End Sub
Else
End If
End Sub
Author: duncanb7 replied at 2024-12-15 06:28:56
It is solved finally and completely with the following the code by error resume next and check whether refresh is done if the cell is empty or not
for destination range. Now it is working fine ,and without the code improvement add , it is still unstable. for double confirmation
So I believe the following code is working
i = 0
Do Until i = 8
Dim sconn As String
Debug.Print sconn
.FieldNames = True
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
.WebTables = "9"
' Sleep (10000)
Range("A" & 16 + i * 67).Select
If Range("A" & 16 + i * 67) = "" Then 'if the cell is empty, it imeans, fail refresh
GoTo Redo
End If
End With
i = i + 1
Redo:
Err.Clear
Loop
i = 0
Do Until i = 8
Dim sconn As String
Debug.Print sconn
.FieldNames = True
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
.WebTables = "9"
' Sleep (10000)
GoTo Redo
End If
End With
i = i + 1
Redo:
Err.Clear
Loop
Expert: Qlemo replied at 2024-12-15 04:32:11
So you want to show how to fight with such trouble - understand that.
In that case you should implement an error handler around the Refresh call, e.g. by not incrementing the counter for the result range. The next loop will then try to read the same page again.
Author: duncanb7 replied at 2024-12-15 03:58:50
That is for Web query tutorial, and that is good example to solve issue from Webquery from website instead of download csv file
Expert: Qlemo replied at 2024-12-14 09:10:49
250 points GOOD
QueryTable.Name does just name the region of cells in Excel. If you do not provide it, it is generated from the URL and an incrementing number appended to create uniqueness. So this is absolutely unrelated.
If the Web Query results are unreliable, that is always a result of timeouts. Some parts of the site might need to long sometimes to get retrieved, so the internal used web browser (which is IE) might stop receiving further contents, rendering the page incomplete. Since you are already using synchronous queries (BackgroundQueries = false), there is nothing you can do about that, sorry.
For tutorials you should try to find a more reliable web page. Keep in mind that some sites do not allow for automated querying, even for teaching purposes. The Yahoo page used seems to be ok for use, since they even allow for downloading as CSV.
Expert: SiddharthRout replied at 2024-12-13 06:35:09
250 points GOOD
Hi I had made a similar program for one of my clients but it used to extract values from Keywords rather than numbers.
For example "VTI" and then so on...
Also see this Addin which I believe does what you want...
http://fransking.blogspot.com/2006/06/getting-stock-prices-into-excel.html
Sid
Sid
