When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-11-17 08:39:04
Point:500 Replies:13 POST_ID:828428USER_ID:11059
JavaScript;;Hypertext Markup Language (HTML)
Do you know where I can find the function or javascript library of responseHTML in other webiste ?
so I can access it through DOM to extract data in other HTML file like
document.getElementById('test').innerHTML =xmlhttp.responseHTML.getElementByID("......)
that is similar to extract xml data from xmlhttp.responseXML
I got one but not complete at http://www.ohjelmointirengas.fi/Ohjelmointi/responseHTML.txt
Please help and advise
Expert: Rob Jurd replied at 2024-11-18 13:21:34
I believe it is because IE caches ajax requests
Author: duncanb7 replied at 2024-11-18 13:14:26
Author: duncanb7 replied at 2024-11-18 13:13:14
thanks for all of you to reply
Please switch to new thread,
I get big problem before using
anything mootools
Author: duncanb7 replied at 2024-11-18 13:09:19
Dear taqit,
Okay thanks, I will remember you, now the big question is at following link , please help to review
http://www.experts-exchange.com/Programming/Languages/Scripting/AJAX/Q_26625196.html.
I don't know why I click may time of the button of the ajax code from wc3 is always
displaying the past data. SO the code is only worked for first time when I open my IE windows
I will credit all the thread to you .
DUncan
DUncan
Expert: Rob Jurd replied at 2024-11-18 13:05:58
the "Request" is part of mootools. without mootools you would have to determine which ajax object to use... see here:
http://www.w3schools.com/ajax/tryit.asp?filename=tryajax_first
the onSuccess is an Event that happens when the Request is completed and receives data back
AJAX = Asynchronous JavaScript and XML.
AJAX is not a new programming language, but a new way to use existing standards.
AJAX is the art of exchanging data with a server, and update parts of a web page - without reloading the whole page.
Of course it will work with D: but as long as you are running it through a local webserver like http://localhost
Expert: Rob Jurd replied at 2024-11-18 13:01:57
all you are doing above is creating a mootools Request object everytime you run "main()". nothing happens because you're not asking it to do anything. you need to tell the request to send()
function main() {myRequest = new Request({ url: "http://www.e-hftrade.com/mootools/screen_update/sales1.htm", noCache: true, link: 'ignore', method: 'get', async: false, onSuccess: function(responseText, responseXML) { $('my_content').innerHTML = responseText; alert($('my_content').getElementsById('Book1_25322').getElementsBYTagName('img').src); } }).send();} 1:2:3:4:5:6:7:8:9:10:11:12:13:
Author: duncanb7 replied at 2024-11-18 07:18:39
It shoud be working but not work, why ? even I also put back <div id="my_content">loading</div>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"><head><title></title><meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /><script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/mootools/1.3.0/mootools-yui-compressed.js"></script><script type='text/javascript'>function main() {myRequest = new Request({ url: "http://www.e-hftrade.com/mootools/screen_update/sales1.htm", noCache: true, link: 'ignore', method: 'get', async: false, onSuccess: function(responseText, responseXML) { $('my_content').innerHTML = responseText; alert($('my_content').getElementsById('Book1_25322').getElementsBYTagName('img').src); } });}</script><input type='button' onclick="main();" value='click me' /><div id="my_content">loading</div></head></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:
Author: duncanb7 replied at 2024-11-18 07:03:36
alert($('my_content').getElement('#Book1_25322').getElement('img').src);
has javascript error
Author: duncanb7 replied at 2024-11-18 06:43:55
Dear Taqit,
it is not wokring and no response for my following try , and your index.html
in other thread is working for sales1.htm so I put this following code file in the same directory
under screen_update
And I want to know which word in your is code calling mootools libray , OnSucess, Right ?
And I found some ajax example is working if I put the code file at D: drive
and some is not like yours. Actually, xmlhttp is internet stuff, so it cannot access file system
on PC, RIght? But I don't know why some ajax example is also working on D: drive.
under screen_update
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"><head><title></title><meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /><script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/mootools/1.3.0/mootools-yui-compressed.js"></script><script type='text/javascript'>function main() {myRequest = new Request({ url: 'sales1.htm', noCache: true, link: 'ignore', method: 'get', async: false, onSuccess: function(responseText, responseXML) { $('my_content').innerHTML = responseText; alert($('my_content').getElement('#Book1_25322').getElement('img').src); } });}</script><input type='button' onclick="main();" value='click me' /></head></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:
Expert: Rob Jurd replied at 2024-11-18 03:05:50
That's right, the html file has to reside in the same domain unless you want to use the additional Request.JSONP package from mootools
see: http://www.clientcide.com/wiki/cnet-libraries/06-request/00-jsonp
Btw You've answered this question in your other question you have open: http://www.experts-exchange.com/Programming/Languages/Scripting/JavaScript/Q_26622228.html?cid=1749
that is the right code. I would focus on using the Request.HTML and the onSuccess function() to obtain the responseHTML content
Expert: Michel Plungjan replied at 2024-11-18 01:07:52
However you will not be able to ajax to another website unless for IE it is in trusted sites and for Fx it implements Cross Origin Resource Sharing
Expert: Rob Jurd replied at 2024-11-17 21:35:19
is the part i'm talking about
Expert: Rob Jurd replied at 2024-11-17 21:34:55
I've used mootools but JQuery will do the same for you. the following is the ajax request object using the mootools library. When the data has been received you can see I load an htm page and then access elements within it using simple css selectors.
myRequest = new Request({ url: "sales1.htm", noCache: true, link: 'ignore', method: 'get', async: false, onSuccess: function(responseText, responseXML) { $('my_content').innerHTML = responseText; alert($('my_content').getElement('#Book1_25322').getElement('img').src); } }); 1:2:3:4:5:6:7:8:9:10:11:
