When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-11-13 03:50:41
Point:500 Replies:9 POST_ID:828423USER_ID:11059
JavaScript;;Asynchronous Javascript and XML (AJAX)
I am using frame and frameset for my wbepage. Suing frame1 to redirect second frame's URL
My question is
how to align body of second frame to its frame top and left I ty this in first fram's html but
it doesn't work, only redirect to www.yahoo.com is successful. Is it any snytax issue ?
parent.secondframename.document.location.href="http://www.yahoo.com";
parent.secondframename.document.body.style.marginTop='0';
parent.secondframename.document.body.style.marginLeft='0';
My question is
Author: duncanb7 replied at 2024-03-07 08:16:36
it is soved yesterday after I put it marginwidth/height in frame tage in Excel sheet
<frame src="" name="frScroll" marginwidth=0 marginheight=0 scrolling=no>"+
But the question, I have 1000 Excel files for production data, I add it in Excel sheet.htm that will
create future problem or slow down file dowload time since need to do open
and insertion of margin code and close.
So I prefer to solve it in main/index html , It might be delay time problem at A point, the link is not ready yet second frame
style.marginTop in fuction is already done and once rediectlink is ready, excelsheet0001's frame tag will
override it. So Probaby using xmlhtttp.statue to set do loop condition for checking redirect link readystate
will solve the issue
Function inputboxRedirectURL() {
parent.secondframename.document.location.href="http://www.mywebsite.com/excelsheet001.htm";
-----------------A point
parent.secondframename.document.body.style.marginLeft='0'; }
Author: duncanb7 replied at 2024-11-14 01:48:30
Expert: elliottbrooks replied at 2024-11-13 14:48:27
Is this online - have you got a link I could take a look at?
Expert: elliottbrooks replied at 2024-11-13 14:43:59
It may be worth inserting a style tag into the header of the excel HTML file itself.
Try the following code, it'll show you all the individual elements of the page and should help pinpoint which bit is causing the mysterious margin/padding...
Author: duncanb7 replied at 2024-11-13 07:18:03
The sceond frame is Excel sheet save as .htm file. In the excel file, there is 3 sheets which is
also set by frame and frameset . Do you think that may make the issue.
<html xmlns:v="urn:schemas-microsoft-com:vml"xmlns:o="urn:schemas-microsoft-com:office:office"xmlns:x="urn:schemas-microsoft-com:office:excel"xmlns="http://www.w3.org/TR/REC-html40"><head><meta name="Excel Workbook Frameset"><meta http-equiv=Content-Type content="text/html; charset=big5"><meta name=ProgId content=Excel.Sheet><meta name=Generator content="Microsoft Excel 11"><link rel=File-List href="1000.files/filelist.xml"><link rel=Edit-Time-Data href="1000.files/editdata.mso"><link rel=OLE-Object-Data href="1000.files/oledata.mso"><!--[if gte mso 9]><xml> <o:DocumentProperties> <o:Author>kkw</o:Author> <o:LastAuthor>kkw</o:LastAuthor> <o:Created>2010-11-06T19:15:01Z</o:Created> <o:LastSaved>2010-11-12T18:45:49Z</o:LastSaved> <o:Version>11.9999</o:Version> </o:DocumentProperties> <o:OfficeDocumentSettings> <o:Colors> <o:Color> <o:Index>14</o:Index> <o:RGB>#DDDDDD</o:RGB> </o:Color> </o:Colors> </o:OfficeDocumentSettings></xml><![endif]--><![if !supportTabStrip]><link id="shLink" href="1000.files/sheet001.htm"><link id="shLink" href="1000.files/sheet002.htm"><link id="shLink"><script language="JavaScript"><!-- var c_lTabs=2; var c_rgszSh=new Array(c_lTabs); c_rgszSh[0] = "Daily13"; c_rgszSh[1] = "Intra13"; var c_rgszClr=new Array(8); c_rgszClr[0]="window"; c_rgszClr[1]="buttonface"; c_rgszClr[2]="windowframe"; c_rgszClr[3]="windowtext"; c_rgszClr[4]="threedlightshadow"; c_rgszClr[5]="threedhighlight"; c_rgszClr[6]="threeddarkshadow"; c_rgszClr[7]="threedshadow"; var g_iShCur; var g_rglTabX=new Array(c_lTabs);function fnGetIEVer(){ var ua=window.navigator.userAgent var msie=ua.indexOf("MSIE") if (msie>0 && window.navigator.platform=="Win32") return parseInt(ua.substring(msie+5,ua.indexOf(".", msie))); else return 0;}function fnBuildFrameset(){ var szHTML="<frameset rows="*,18" border=0 width=0 frameborder=no framespacing=0>"+ "<frame src=""+document.all.item("shLink")[0].href+"" name="frSheet" noresize >"+ "<frameset cols="54,*" border=0 width=0 frameborder=no framespacing=0>"+ "<frame src="" name="frScroll" marginwidth=0 marginheight=0 scrolling=no>"+ "<frame src="" name="frTabs" marginwidth=0 marginheight=0 scrolling=no>"+ "</frameset></frameset><plaintext>"; with (document) { open("text/html","replace"); write(szHTML); close(); } fnBuildTabStrip();}function fnBuildTabStrip(){ var szHTML= "<html><head><style>.clScroll {font:8pt Courier New;color:"+c_rgszClr[6]+";cursor:default;line-height:10pt;}"+ ".clScroll2 {font:10pt Arial;color:"+c_rgszClr[6]+";cursor:default;line-height:11pt;}</style></head>"+ "<body onclick="event.returnValue=false;" ondragstart="event.returnValue=false;" onselectstart="event.returnValue=false;" bgcolor="+c_rgszClr[4]+" topmargin=0 leftmargin=0><table cellpadding=0 cellspacing=0 width=100%>"+ "<tr><td colspan=6 height=1 bgcolor="+c_rgszClr[2]+"></td></tr>"+ "<tr><td style="font:1pt"> <td>"+ "<td valign=top id=tdScroll class="clScroll" onclick="parent.fnFastScrollTabs(0);" onmouseover="parent.fnMouseOverScroll(0);" onmouseout="parent.fnMouseOutScroll(0);"><a>«</a></td>"+ "<td valign=top id=tdScroll class="clScroll2" onclick="parent.fnScrollTabs(0);" ondblclick="parent.fnScrollTabs(0);" onmouseover="parent.fnMouseOverScroll(1);" onmouseout="parent.fnMouseOutScroll(1);"><a><</a></td>"+ "<td valign=top id=tdScroll class="clScroll2" onclick="parent.fnScrollTabs(1);" ondblclick="parent.fnScrollTabs(1);" onmouseover="parent.fnMouseOverScroll(2);" onmouseout="parent.fnMouseOutScroll(2);"><a>></a></td>"+ "<td valign=top id=tdScroll class="clScroll" onclick="parent.fnFastScrollTabs(1);" onmouseover="parent.fnMouseOverScroll(3);" onmouseout="parent.fnMouseOutScroll(3);"><a>»</a></td>"+ "<td style="font:1pt"> <td></tr></table></body></html>"; with (frames['frScroll'].document) { open("text/html","replace"); write(szHTML); close(); } szHTML = "<html><head>"+ "<style>A:link,A:visited,A:active {text-decoration:none;"+"color:"+c_rgszClr[3]+";}"+ ".clTab {cursor:hand;background:"+c_rgszClr[1]+";font:9pt ¿¿¿¿;padding-left:3px;padding-right:3px;text-align:center;}"+ ".clBorder {background:"+c_rgszClr[2]+";font:1pt;}"+ "</style></head><body onload="parent.fnInit();" onselectstart="event.returnValue=false;" ondragstart="event.returnValue=false;" bgcolor="+c_rgszClr[4]+ " topmargin=0 leftmargin=0><table id=tbTabs cellpadding=0 cellspacing=0>"; var iCellCount=(c_lTabs+1)*2; var i; for (i=0;i<iCellCount;i+=2) szHTML+="<col width=1><col>"; var iRow; for (iRow=0;iRow<6;iRow++) { szHTML+="<tr>"; if (iRow==5) szHTML+="<td colspan="+iCellCount+"></td>"; else { if (iRow==0) { for(i=0;i<iCellCount;i++) szHTML+="<td height=1 class="clBorder"></td>"; } else if (iRow==1) { for(i=0;i<c_lTabs;i++) { szHTML+="<td height=1 nowrap class="clBorder"> </td>"; szHTML+= "<td id=tdTab height=1 nowrap class="clTab" onmouseover="parent.fnMouseOverTab("+i+");" onmouseout="parent.fnMouseOutTab("+i+");">"+ "<a href=""+document.all.item("shLink")[i].href+"" target="frSheet" id=aTab> "+c_rgszSh[i]+" </a></td>"; } szHTML+="<td id=tdTab height=1 nowrap class="clBorder"><a id=aTab> </a></td><td width=100%></td>"; } else if (iRow==2) { for (i=0;i<c_lTabs;i++) szHTML+="<td height=1></td><td height=1 class="clBorder"></td>"; szHTML+="<td height=1></td><td height=1></td>"; } else if (iRow==3) { for (i=0;i<iCellCount;i++) szHTML+="<td height=1></td>"; } else if (iRow==4) { for (i=0;i<c_lTabs;i++) szHTML+="<td height=1 width=1></td><td height=1></td>"; szHTML+="<td height=1 width=1></td><td></td>"; } } szHTML+="</tr>"; } szHTML+="</table></body></html>"; with (frames['frTabs'].document) { open("text/html","replace"); charset=document.charset; write(szHTML); close(); }}function fnInit(){ g_rglTabX[0]=0; var i; for (i=1;i<=c_lTabs;i++) with (frames['frTabs'].document.all.tbTabs.rows[1].cells[fnTabToCol(i-1)]) g_rglTabX[i]=offsetLeft+offsetWidth-6;}function fnTabToCol(iTab){ return 2*iTab+1;}function fnNextTab(fDir){ var iNextTab=-1; var i; with (frames['frTabs'].document.body) { if (fDir==0) { if (scrollLeft>0) { for (i=0;i<c_lTabs&&g_rglTabX[i]<scrollLeft;i++); if (i<c_lTabs) iNextTab=i-1; } } else { if (g_rglTabX[c_lTabs]+6>offsetWidth+scrollLeft) { for (i=0;i<c_lTabs&&g_rglTabX[i]<=scrollLeft;i++); if (i<c_lTabs) iNextTab=i; } } } return iNextTab;}function fnScrollTabs(fDir){ var iNextTab=fnNextTab(fDir); if (iNextTab>=0) { frames['frTabs'].scroll(g_rglTabX[iNextTab],0); return true; } else return false;}function fnFastScrollTabs(fDir){ if (c_lTabs>16) frames['frTabs'].scroll(g_rglTabX[fDir?c_lTabs-1:0],0); else if (fnScrollTabs(fDir)>0) window.setTimeout("fnFastScrollTabs("+fDir+");",5);}function fnSetTabProps(iTab,fActive){ var iCol=fnTabToCol(iTab); var i; if (iTab>=0) { with (frames['frTabs'].document.all) { with (tbTabs) { for (i=0;i<=4;i++) { with (rows[i]) { if (i==0) cells[iCol].style.background=c_rgszClr[fActive?0:2]; else if (i>0 && i<4) { if (fActive) { cells[iCol-1].style.background=c_rgszClr[2]; cells[iCol].style.background=c_rgszClr[0]; cells[iCol+1].style.background=c_rgszClr[2]; } else { if (i==1) { cells[iCol-1].style.background=c_rgszClr[2]; cells[iCol].style.background=c_rgszClr[1]; cells[iCol+1].style.background=c_rgszClr[2]; } else { cells[iCol-1].style.background=c_rgszClr[4]; cells[iCol].style.background=c_rgszClr[(i==2)?2:4]; cells[iCol+1].style.background=c_rgszClr[4]; } } } else cells[iCol].style.background=c_rgszClr[fActive?2:4]; } } } with (aTab[iTab].style) { cursor=(fActive?"default":"hand"); color=c_rgszClr[3]; } } }}function fnMouseOverScroll(iCtl){ frames['frScroll'].document.all.tdScroll[iCtl].style.color=c_rgszClr[7];}function fnMouseOutScroll(iCtl){ frames['frScroll'].document.all.tdScroll[iCtl].style.color=c_rgszClr[6];}function fnMouseOverTab(iTab){ if (iTab!=g_iShCur) { var iCol=fnTabToCol(iTab); with (frames['frTabs'].document.all) { tdTab[iTab].style.background=c_rgszClr[5]; } }}function fnMouseOutTab(iTab){ if (iTab>=0) { var elFrom=frames['frTabs'].event.srcElement; var elTo=frames['frTabs'].event.toElement; if ((!elTo) || (elFrom.tagName==elTo.tagName) || (elTo.tagName=="A" && elTo.parentElement!=elFrom) || (elFrom.tagName=="A" && elFrom.parentElement!=elTo)) { if (iTab!=g_iShCur) { with (frames['frTabs'].document.all) { tdTab[iTab].style.background=c_rgszClr[1]; } } } }}function fnSetActiveSheet(iSh){ if (iSh!=g_iShCur) { fnSetTabProps(g_iShCur,false); fnSetTabProps(iSh,true); g_iShCur=iSh; }} window.g_iIEVer=fnGetIEVer(); if (window.g_iIEVer>=4) fnBuildFrameset();//--></script><![endif]><!--[if gte mso 9]><xml> <x:ExcelWorkbook> <x:ExcelWorksheets> <x:ExcelWorksheet> <x:Name>Daily13</x:Name> <x:WorksheetSource HRef="1000.files/sheet001.htm"/> </x:ExcelWorksheet> <x:ExcelWorksheet> <x:Name>Intra13</x:Name> <x:WorksheetSource HRef="1000.files/sheet002.htm"/> </x:ExcelWorksheet> </x:ExcelWorksheets> <x:Stylesheet HRef="1000.files/stylesheet.css"/> <x:WindowHeight>6225</x:WindowHeight> <x:WindowWidth>13995</x:WindowWidth> <x:WindowTopX>480</x:WindowTopX> <x:WindowTopY>120</x:WindowTopY> <x:ProtectStructure>False</x:ProtectStructure> <x:ProtectWindows>False</x:ProtectWindows> </x:ExcelWorkbook> <x:ExcelName> <x:Name>¿¿¿¿_1</x:Name> <x:SheetIndex>2</x:SheetIndex> <x:Formula>=Intra13!#REF!</x:Formula> </x:ExcelName> <x:ExcelName> <x:Name>¿¿¿¿_2</x:Name> <x:SheetIndex>2</x:SheetIndex> <x:Formula>=Intra13!#REF!</x:Formula> </x:ExcelName> <x:ExcelName> <x:Name>¿¿¿¿_3</x:Name> <x:SheetIndex>2</x:SheetIndex> <x:Formula>=Intra13!#REF!</x:Formula> </x:ExcelName></xml><![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="9218"/></xml><![endif]--></head><frameset rows="*,39" border=0 width=0 frameborder=no framespacing=0> <frame src="1000.files/sheet001.htm" name="frSheet"> <frame src="1000.files/tabstrip.htm" name="frTabs" marginwidth=0 marginheight=0> <noframes> <body> </body> </noframes></frameset></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:56:57:58:59:60:61:62:63:64:65:66:67:68:69:70:71:72:73:74:75:76:77:78:79:80:81:82:83:84:85:86:87:88:89:90:91:92:93:94:95:96:97:98:99:100:101:102:103:104:105:106:107:108:109:110:111:112:113:114:115:116:117:118:119:120:121:122:123:124:125:126:127:128:129:130:131:132:133:134:135:136:137:138:139:140:141:142:143:144:145:146:147:148:149:150:151:152:153:154:155:156:157:158:159:160:161:162:163:164:165:166:167:168:169:170:171:172:173:174:175:176:177:178:179:180:181:182:183:184:185:186:187:188:189:190:191:192:193:194:195:196:197:198:199:200:201:202:203:204:205:206:207:208:209:210:211:212:213:214:215:216:217:218:219:220:221:222:223:224:225:226:227:228:229:230:231:232:233:234:235:236:237:238:239:240:241:242:243:244:245:246:247:248:249:250:251:252:253:254:255:256:257:258:259:260:261:262:263:264:265:266:267:268:269:270:271:272:273:274:275:276:277:278:279:280:281:282:283:284:285:286:287:288:289:290:291:292:293:294:295:296:297:298:299:300:301:302:303:304:305:306:307:308:309:310:311:312:313:314:315:316:317:318:319:320:321:322:323:324:325:326:327:328:329:330:331:332:333:334:335:336:337:338:339:340:341:342:343:344:345:346:347:348:349:350:351:352:353:354:355:356:357:358:359:360:361:362:363:364:365:
Expert: elliottbrooks replied at 2024-11-13 06:12:44
That is odd - is it just a specific URL that causes this issue or any URL the frame loads?
Author: duncanb7 replied at 2024-11-13 05:51:29
Since the redirect URL is always changing, so I could not write every html with <style>margain:0px<style>
Author: duncanb7 replied at 2024-11-13 05:50:00
it is same as before for trying padding
If I go to the second frame's html and set style tag to merge body to frame that is no issue at all. So I don't
know why that is not working for parent.second
Expert: elliottbrooks replied at 2024-11-13 05:10:51
Does changing the padding instead work?
parent.secondframename.document.body.style.paddingTop='0';
parent.secondframename.document.body.style.paddingLeft='0';
